Headlight upgrade - JeepForum.com
post #1 of 27 Old 02-02-2013, 10:09 PM Thread Starter
Jsadamson1
Headlight upgrade
So my headlight went out and it's time for a replacement. Are any of the upgraded headlights worth the extra expense? Anybody have info/reviews on the matter?
Follow my Jeep Builds!
jeepbuilds.blogspot.com
Jsadamson1 is offline
post #2 of 27 Old 02-02-2013, 11:17 PM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
I put the new Truck-Lite phase 7 LEDs in my TJ before Xmas. HUGE difference. Plug and play.
Mail crawling.
MisfitSeven is offline
post #3 of 27 Old 02-03-2013, 10:18 AM
hmantractors
2004 KJ Liberty
Headlights
SILVERSTARS IN MINE. WHAT AN IMPROVEMENT. ABOUT $25.00 APIECE O'REILLYS.
hmantractors is offline
post #4 of 27 Old 02-03-2013, 10:33 AM
mvigo
mvigo's Avatar
or, you can really get an improvement and upgrade your headlight wiring harness using relays...
these threads me helped immensely:
http://www.jeepforum.com/forum/f20/m...inside-510221/
In this thread JeepHammer goes into detail on what to do:
http://www.jeepforum.com/forum/f8/he...t-mods-686559/
I bought my parts from Daniel Stern, his website is helpful as well:
http://www.danielsternlighting.com/
once you complete this easy project, any head lamp you throw on your Jeep is a vast improvement because your new wiring harness can supply the adequate juice to the lights instead of starving them with the stock OEM wiring. A very worthwhile project...
1985 CJ-7, fuel injected 258, 2.5" Rubicon Express Extreme Duty Lift, 1" Body lift, Crabtree Shackle Hangers, T-5, Dana 300 w/ 4:1 Teralow kit, Dana 30, AMC 20 w/1 piece axle, 3.73 's with Detroit Truetrac front and rear, riding on 32x11.5x15" Cooper Discoverer STT mud terrains
mvigo is offline
post #5 of 27 Old 02-03-2013, 11:43 AM
NOCHEEPGAS
1980 CJ5
I have these http://www.roundeyes.com/Products-Jeep_Headlamps.html and really like the optics. Once you replace the bulb housings then the H-4 replacement bulbs are available at your nearest parts store. Oh, and they are way cheaper than going to LEDs.
NOCHEEPGAS is offline
post #6 of 27 Old 02-03-2013, 11:45 AM
RobsCrawlin7
no balls
RobsCrawlin7's Avatar
I use regular stock replacement lights and upgraded my harness like mvigo said, MUCH better than stock and saved a ton on aftermarket lights.
'01 TJ 4.7/NV3550, 2" lift, 35's, locked.
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
SSG David Mejias, SSG Eric Vick, SGT William Bowling, SGT Robert McDowell
1 April 2007
Rest In Peace Brothers
RobsCrawlin7 is offline
post #7 of 27 Old 02-03-2013, 12:11 PM
MoC
I am getting ready to do this as well. Has anyone found a good aftermarket source for a water proof relay "box," as opposed to going to the junkyard and digging around?
MoC is offline
post #8 of 27 Old 02-03-2013, 12:13 PM
fourbtgait
1930 MK Patriot
Originally Posted by mvigo
I had not seen this one before, it is a very good write up/schematic. I like his idea of using the existing headlamp base for the relay trigger, though I won't be doing it that way.
fourbtgait is offline
post #9 of 27 Old 02-03-2013, 12:14 PM
RobsCrawlin7
no balls
I used some from advance, they look just like this one
http://www.amazon.com/Parts-Express-.../dp/B000PHLQJW
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
1 April 2007
post #10 of 27 Old 02-03-2013, 12:18 PM
19in1979
1979 CJ7
I'm looking at this http://www.ebay.com/itm/370658138040
CERAMIC H4 HEADLIGHT RELAY WIRING HARNESS 2 HEADLAMP LIGHT BULB SOCKET PLUGS 7"
Looks pretty universal and takes a lot of the work out.
Best regards,
Wayne
Living the dream at 8,500ft. elevation in beautiful Coal Creek Canyon, Colorado.
19in1979 is offline
post #11 of 27 Old 02-03-2013, 12:19 PM
MoC
Sorry, I meant the block that they actually plug in to. Painless makes one, but its around $132.
MoC is offline
post #12 of 27 Old 02-03-2013, 12:21 PM
RobsCrawlin7
no balls
my thoughts on this are
A: I like to wire stuff myself as to avoid not enough/too much wire
B: the gauge of that wire looks no better than stock
Personally I would rather run it myself and be able to put the relays, wire where I want instead of being limited by wire length or having excess so it looks like crap.
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
1 April 2007
post #13 of 27 Old 02-03-2013, 12:22 PM
RobsCrawlin7
no balls
not sure what you mean, are you talking about the little pelican/tuperware type boxes with the relays inside them? what would be the point when the relays are already sealed?
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
1 April 2007
post #14 of 27 Old 02-03-2013, 12:23 PM
19in1979
1979 CJ7
Makes total sense. I just happened upon it this morning and hadn't really looked close at it...not enough coffee yet.
Best regards,
Wayne
19in1979 is offline
post #15 of 27 Old 02-03-2013, 12:26 PM
lucdog
lucdog's Avatar
1980 CJ5
I use Tupperware containers, the ones with the vent tab on the top. In your case, the lid matches your paint (close anyway) (picture)
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
