Headlight Switch - JeepForum.com
post #1 of 12 Old 11-25-2009, 03:46 PM Thread Starter
br00klyn722
Headlight Switch
Does anyone know where to get the wiring clip for the headlight switch on the floor. Mine is all rotted out. i found the actual switch on morris 4x4 but cant find the clip anywhere
br00klyn722 is offline
post #2 of 12 Old 11-25-2009, 04:34 PM
WayneMeuir
1980 CJ5
If you are talking about the plug, it is part of the underdash wiring harness and you will most likely have to find a used one. They may be available but I would not know where to find one.
Wayne
WayneMeuir is offline
post #3 of 12 Old 11-25-2009, 05:52 PM
BlueRubiconrich
Try 4WD.com
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #4 of 12 Old 11-25-2009, 09:15 PM
ARJeepNerd
1981 CJ5
You mean the dimmer switch?
Electrical gurus chime in if this is unsafe, but I had the same problem. Used Autozone female spade connectors soldered to the factory wires and clipped on the dimmer switch terminals. Then, I covered each one in di-e grease. Finally, took some black RTV and filled in/filleted all around them to create a homeade plug. It has worked for a couple of years, but is it safe? That is the question. Hope this helps!
ARJeepNerd is offline
post #5 of 12 Old 11-25-2009, 09:24 PM
brian613
1977 CJ5
its not factory correct but as long as it stays connected and cant short out i dont see anything wrong with it
brian613 is offline
post #6 of 12 Old 11-27-2009, 09:36 PM
james04si
james04si's Avatar
1977 CJ5
james04si is offline
post #7 of 12 Old 11-28-2009, 01:47 AM
OldSailor
1977 CJ7
Call one of the companies that make modern aftermarket wiring harnesses (e.g., Painless Wiring; Centech Wiring). Since they use the connectors when fabbing their harnesses, they'd probably sell you the connector alone -- it might even have pigtails on it.
1977 CJ7, AMC360 V8 w/ headers, DUI HEI, Edelbrock intake, Holley 4150 carb, , TF999, D300, D30 front and AMC20 rear with 4.56 gears and lockers both ends, 4" susp lift, 2.5" body lift, 35" BFGs, ARG steering, 8000-lb winch, etc.
OldSailor is offline
post #8 of 12 Old 11-28-2009, 06:56 AM
Mike Romain
The 'help' brand of parts that a lot of auto parts stores carry have this plug and pigtail wires for cheap.
A full sized older GM Van or pickup at the wreckers will also have this.
If you have a choice, buy the Mopar or GM expensive dimmer switch. (my last one was Mopar) The cheap aftermarket ones only lasted me about a year.
Mike
Mike Romain is offline
post #9 of 12 Old 11-28-2009, 08:42 AM
Redmanchew
Redmanchew's Avatar
1982 CJ7
I got mine for the same problem a few weeks ago at advance. The store didnt have it but they got it in 2 days for a whopping $3.00.
1982 CJ-7 2003 4.3 chevy vortec, 4L60E, Clocked Dana 300 35 x 12.5 x 15 KM2 on Cragar 399's. Vanco Brake Booster. Power steering conversion. Warn front and rear bumpers with swing away. Moser 1 piece rears. Rear OX.
Support your local MS foundation. You don't know how much this disease sucks until it affects someone you love.
Originally Posted by twoleos617 View Post
To reiterate for the 1,067th time, when towing...
remove rear axle, xfer in N, trans in 5th, remove neg batt cable, key to Run and go??
Redmanchew is offline
post #10 of 12 Old 11-28-2009, 06:09 PM Thread Starter
br00klyn722
its not the switch itself i found that @ morris 4x4
Dimmer Switch*5461816 by the Jeep Specialists | Morris 4x4 Center
its the clip that connects to the dimmer.
im gonna try calling on monday old sailer maybe they will hook me up.
James thanks for the help but i cant tell if they are what i need the pics are not coming up
post #11 of 12 Old 11-28-2009, 10:06 PM
brian613
1977 CJ5
what about calling a place that makes wiring harnesses like painless or one of the other places and see if they sell the connectors..
brian613 is offline
post #12 of 12 Old 11-29-2009, 06:35 AM
Mike Romain
We can get that plug and pigtail wires at any local parts store that carries the 'help' brand of parts. They are very common.
Mike
YJ Guy needs CJ Headlight Switch Help JeeperDon Jeep CJ Forum 5 02-05-2010 04:57 PM
78 cj7 headlight switch crazyinmaine Jeep CJ Forum 2 08-27-2009 03:49 PM
Headlight/Headlight Switch Fix - Preventive IdahoJeeper Jeep CJ Forum 9 08-01-2009 04:08 PM
"Switch" Multi-Terinal Headlight Switch 2 Simple Rocker? whizerd Jeep CJ Forum 6 04-11-2008 10:51 AM
Help with CJ5 77 headlight switch (pic) atom73 Jeep CJ Forum 2 05-05-2007 10:49 AM
