headlight mods - Page 3 - JeepForum.com
post #31 of 33 Old 11-15-2011, 12:10 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Where did you find those pigtails?
Rick
Cutlass327 is offline
post #32 of 33 Old 11-15-2011, 05:50 PM
Mike Romain
Originally Posted by danattherock View Post
Thanks man. I appreciate the rationale for relays. Honestly, don't know much about wiring and find the project a bit intimidating. Sounds like a worthwhile upgrade though. I would love to have some brighter lights on my Jeep, if nothing else to reduce the likely hood of hitting a deer and such on the country roads near home.
-Dan
I have done a couple vehicles in the last couple weeks and it is less than an hour to do for me anyway.
I bought the relays and the pigtails for the relays at a local auto parts store along with an inline fuse holder and double walled waterproof heatshrink tubing because I solder my connections. Crimp connectors will work too but... They even sell crimp connectors that have their own heat shrink tubing these days, I just live in the rust belt so dislike crimps.
You just have to cut the one wire to the headlights and use the end from the switch to trigger the relay so the relay feeds the other end direct fused power. Take your time and it's not hard to do.
Mike
Mike Romain is offline
post #33 of 33 Old 11-15-2011, 08:17 PM Thread Starter
maxamillion
1978 CJ7
http://www.quadratec.com/products/97018_2430.htm
Ok so found these at quadratec going to call tomorrow to see if this would be the right upgrade for the old wiring i have in the jeep.
maxamillion is offline
headlight , headlight upgrade , led , wiring
headlight mods..... starfire340 Jeep CJ Forum 113 04-10-2016 09:25 AM
Headlight/Headlight Switch Fix - Preventive IdahoJeeper Jeep CJ Forum 9 08-01-2009 05:08 PM
360 mods going on !!! SparkyCJ7 Jeep CJ Forum 5 06-14-2009 09:20 PM
Need Help With Mods KINGJRK1974CJ5 Jeep CJ Forum 2 01-25-2008 11:39 PM
Hi, any mods that should be done first? Snowsk5054 Jeep CJ Forum 12 08-02-2004 10:04 PM
