Headlight ground - JeepForum.com
post #1 of 10 Old 10-17-2011, 04:41 PM Thread Starter
CJ Runner
1978 CJ5
Headlight ground
All lights except my headlights and front parking lights work on my 78 CJ5. The side parking lights are pretty dim. I see on my harness that there are three wires going into the headlight. I'm assuming one is low beam power, one is high beam power, and one is ground. Is the headlight frame supposed to be grounded for them to com on?
1978 CJ5
Fiberglass Body
Reman AMC 360
T-150 3 Speed Transmission
CJ Runner is offline
post #2 of 10 Old 10-17-2011, 04:49 PM
redman87
1964 CJ5
Yes the grill/radiator support should be grounded. But your lights should still work. I would start with checking the head light switch, fuses, and anywhere the wires may touch any sharp edges
redman87 is offline
post #3 of 10 Old 10-17-2011, 04:54 PM
redman87
1964 CJ5
Yes the grill/radiator support should be grounded. But your lights should still work. I would start with checking the head light switch, fuses, and anywhere the wires may touch any sharp edges.
redman87 is offline
post #4 of 10 Old 10-17-2011, 04:58 PM
redman87
1964 CJ5
Sorry about the double post having some wifi trouble
redman87 is offline
post #5 of 10 Old 10-17-2011, 05:12 PM
bentring
1976 CJ5
Here's a good thread you should read if you have problems with grounds.
bentring is offline
post #6 of 10 Old 10-17-2011, 05:19 PM
ODGREEN4X4
Head lights
Take a test light to the wires or clip and see if there is any positive power(ground to the neg batt term). 1 wire should be high and one should be low beam. If there is power- take the test light ( off the batt ground ) and ground it to the other wire /clip .if the power goes out it is the ground. This will tell you if it is a ground or hot wire issue. assuming all the bulbs are good. Don,t laugh it happened to me.
ODGREEN4X4 is offline
post #7 of 10 Old 11-16-2011, 05:30 PM Thread Starter
CJ Runner
1978 CJ5
I grounded my test light to the negative terminal of the battery and touched the test light to the parking light and it lit up. Did the same to the headlight and got nothing. I checked to see if power was going through the headlight fuse and it was. When I touched the test light on the engine compartment side of the fuse block where the headlight wires terminate into the fuse block I got nothing
Not really what to check from here, any advise is appreciated.
1978 CJ5
Fiberglass Body
Reman AMC 360
post #8 of 10 Old 11-16-2011, 06:31 PM
addicted2dunes
1981 CJ8
Sounds like your dimmer switch (switch on the floor to switch between hi/lo beams) is bad. Check for power at the dimmer switch, plug looks like this:
If you have power in the center wire terminal then try a jumper wire from the center terminal to one of the other sockets and see if you get lights, oh yeah, when testing all of this make sure the headlight switch is on. If you don't have power at the dimmer switch it'll then move you to diagnosing the headlight switch.
Cameron Gunlock
1981 CJ8 -
http://www.facebook.com/pages/Central-Coast-Krawlers/139075302856004
addicted2dunes is offline
post #9 of 10 Old 11-16-2011, 06:36 PM
addicted2dunes
1981 CJ8
Do the taillights work? If not it sounds like it might be your headlight switch.......
Cameron Gunlock
1981 CJ8 -
post #10 of 10 Old 11-16-2011, 06:59 PM Thread Starter
CJ Runner
1978 CJ5
You are the man...time for a victory beer. It was the dimmer switch, swapped in a spare and they lit right up; thanks!!
1978 CJ5
Fiberglass Body
Reman AMC 360
Headlight/Headlight Switch Fix - Preventive IdahoJeeper Jeep CJ Forum 9 08-01-2009 04:08 PM
cj5 ground up troy.j Jeep CJ Forum 4 02-16-2009 07:24 AM
Help with ground!! jimbos76cj Jeep CJ Forum 4 06-10-2007 01:14 PM
Tub ground Pick01 Jeep CJ Forum 3 04-13-2007 04:55 PM
where is the ground? mike360 Jeep CJ Forum 3 08-03-2006 06:15 PM
