Headlight Bucket Repair ????? - JeepForum.com
post #1 of 35 Old 06-27-2012, 07:18 PM Thread Starter
imafishingfred
imafishingfred's Avatar
1981 CJ7
The adjuster screws on my sons 79 CJ7 have stripped and he has no adjustment of the headlight direction. I did a search on headlight bucket repair and only came up with wiring repairs. Have any of you run in to this problem and how did you fix it? New buckets are $$$.$$ plus shipping and there has to be a better solution. Any help would be appreciated.
imafishingfred is offline
post #2 of 35 Old 06-27-2012, 07:30 PM
EtownMedic
I ziptied mine in place. Not the greatest solution but it works. Just put them on the garage door or a wall and you can line them up and zip time them in place. My rings went over top of them and you cant even tell
EtownMedic is offline
post #3 of 35 Old 06-27-2012, 08:08 PM
davbytrace
1979 CJ7
Just use some bigger screws.
davbytrace is offline
post #4 of 35 Old 06-27-2012, 08:19 PM
lucdog
lucdog's Avatar
1980 CJ5
I dought bigger screws are a option. The adjust screws have the reduction in the shank for adjustment. I don't remember seeing larger ones anywhere.
One thing you might try is the smallest SS hose clamp around the outside. Some of mine were cracked, the clamps worked for me. You might also check the "help section" at parts stores.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #5 of 35 Old 06-27-2012, 08:31 PM
Skerr
Or send MoC a PM to see if he has used buckets that are in good shape.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #6 of 35 Old 06-27-2012, 08:31 PM
MoC
I have a set of buckets for $50 shipped if you are interested. PM me.
MoC is offline
post #7 of 35 Old 06-27-2012, 08:32 PM
MoC
lol, 1 2 3 4 jinx!! We posted at the same time!
MoC is offline
post #8 of 35 Old 06-27-2012, 10:21 PM
outdoorguy86
1983 CJ7
The plastic on mine snapped, so what I did was mix up some epoxy and cabosil (you could also use micro balloons) this makes the epoxy into a peanut butter consistency. Put a bunch of chapstick on the screw stick it in there and glob on the epoxy. When it hardens you can unscrew the screw still.
Colorado Jeep Club Member #2086
/l , [____],
l---L---OlllllllO-
()_) ()_)=@=)_)
outdoorguy86 is offline
post #9 of 35 Old 06-27-2012, 10:32 PM
only in a jeep cj
Ive repaired them two ways, the first was I removed the stripped plastic threaded part by drilling out the rivet and replaced it with a good one from another broken bucket. A small screw or rivet does the trick.
The other way was when I didn't have a replacement part, I welded the correct thread nut on the end of a metal bracket that located it in the right spot. More fab work, but it wont strip again like the plastic.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #10 of 35 Old 06-28-2012, 04:57 AM Thread Starter
imafishingfred
1981 CJ7
Thats what I did for the time being.
Fabrication I can Handle. This sounds like the best solution. Do you happen to remember the correct thread? I'm at work and could build them before I leave for the day.
post #11 of 35 Old 06-28-2012, 05:51 AM
Skerr
That's a cool idea! New uses for my cabosil.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #12 of 35 Old 06-28-2012, 09:23 AM
outdoorguy86
1983 CJ7
epoxy and cabosil is big boy Bondo
I try and stay away from the polyester resin if I can
Using the micro and the waxed threads will allow you to create threaded holes anywhere you want on your glass tub. I did that to fill in the stripped out holes the PO left for the hard top.
/l , [____],
l---L---OlllllllO-
()_) ()_)=@=)_)
post #13 of 35 Old 06-28-2012, 10:10 AM
my-jeep-earl
1971 CJ5
When my son put a CJ grill and hood on his YJ, I got the headlight buckets from a Pick-N-Pull out of a Chevy pickup. The small parts I needed, I got from the "odd ball" rack at almost all auto parts stores. They went in with very minor modifications, fit perfectially.
my-jeep-earl is offline
post #14 of 35 Old 06-28-2012, 10:27 AM
Skerr
I never thought of that. What a great idea.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #15 of 35 Old 06-28-2012, 04:11 PM
jaxfljeep
1980 CJ7
You can get the replacement adjusters at the auto parts store out in the aisles with all the other replacement doo-dads...Then drill out the old rivets and screw or rivet the new ones in place as suggested by only in a jeep Ed.
jaxfljeep is offline
Can i adapt ANY bucket seats Wilderness Jeep CJ Forum 26 11-15-2013 10:20 AM
5k rust bucket for sale trj1393 Jeep CJ Forum 13 06-19-2012 11:51 PM
Rust Bucket for a Tub. Jeaux Jeep CJ Forum 7 01-12-2010 10:25 AM
81' CJ7 rust bucket value MakoML Jeep CJ Forum 11 07-29-2009 07:20 AM
bucket seats on 57 cj5 ktm25089 Jeep CJ Forum 9 04-29-2008 01:13 PM
