Headlight bucket or adjustment nut?? - JeepForum.com
post #1 of 8 Old 09-18-2017, 06:34 PM Thread Starter
SAVRICH
So I go to adjust my headlights and the threads inside of the beige looking tube on the top of the bracket ring, that the adjustment screw goes into, are stripped. It is riveted onto the ring so I'm assuming ill have to replace this entire piece. I cannot find one anywhere online that is similar to mine, which I'm assuming is original. Can anyone help that has had this problem before ??
1985 Cj7
SAVRICH is offline
post #2 of 8 Old 09-18-2017, 06:56 PM
only in a jeep cj
EASY to fix for free
Find a small piece of thin metal like sheet metal.
Drill a hole and tap it for the correct thread pitch.
Use tin snips to cut out a square around the hole that will fit the backside of the plastic mount.
Reassemble and be sure to grease where the inner bucket slides on the outer bucket.
It will work smooth and not strip out again.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #3 of 8 Old 09-18-2017, 07:02 PM Thread Starter
SAVRICH
Drop a hole and tap it for the correct thread pitch.
not sure i am understanding this.
i believe i understand you're saying to make a small tin square for the adjustment screw to screw into, but fit the backside of the mount is where you lost me.
thanks
1985 Cj7
SAVRICH is offline
post #4 of 8 Old 09-18-2017, 08:51 PM
Mortgage-payer
1976 CJ7
scoutparts.com
I've seen them on eBay too.
I call it a distributor, not a dizzy.
Mortgage-payer is offline
post #5 of 8 Old 09-18-2017, 09:16 PM
Brianscj5
I just drilled out the rivet and bolted the new adjuster on. Worked great.
Brianscj5 is offline
post #6 of 8 Old 09-19-2017, 05:59 AM Thread Starter
SAVRICH
Originally Posted by Mortgage-payer View Post
scoutparts.com
Thanks
Which replacements did you purchase?
1985 Cj7
SAVRICH is offline
post #7 of 8 Old 09-19-2017, 04:20 PM
Brianscj5
Which replacements did you purchase?[/QUOTE]
I bought them off eBay, I will look to see if I can find them tonight after work.
Found them:
https://m.ebay.com/itm/190753565605?_mwBanner=1
I just cut the little round peg off and they fit perfect.
post #8 of 8 Old 09-20-2017, 07:10 AM Thread Starter
SAVRICH
Almost paid $22 for two of those, Thanks
1985 Cj7
SAVRICH is offline
