Headlight Bezels - JeepForum.com
post #1 of 7 Old 09-05-2013, 11:42 AM Thread Starter
Gigemags05
1980 CJ7
Headlight Bezels
I had a headlight bezel fall off my 1980 cj7 other day. Upon inspection, the tab that holds it onto the jeep is broken.
My question:
The bezels on my lights are black. I cannot find any black ones anywhere. Were headlight bezels ever black on a cj?
If not, I can get a set of chrome ones. In fact, I found a set that came off of an older (owner not sure of yr) CJ. Will the bezels from all cj's work on my 1980 cj?
Gigemags05 is offline
post #2 of 7 Old 09-05-2013, 11:52 AM
walkerhoundvm
1981 CJ8
72-86 at least. I've never seen OEM black
walkerhoundvm is offline
post #3 of 7 Old 09-05-2013, 11:54 AM
2Xtreme
2Xtreme's Avatar
1979 CJ7
If you have chrome bezels you can scuff them up good with sandpaper, hit them with a couple coats of etching primer followed by a few coats of rattle can black.... easy peasy!
2Xtreme is offline
post #4 of 7 Old 09-05-2013, 12:03 PM Thread Starter
Gigemags05
1980 CJ7
If there were never any OEM black ones, I have no issues with going to chrome ones.
If I can find just one for pretty cheap I might consider painting it black.
post #5 of 7 Old 09-05-2013, 01:12 PM
walkerhoundvm
1981 CJ8
Those tabs are a beeyotch - do you still have it, and access to a welder? That's what I would've done if I had a welder, but instead I just bought Omix replicas.
post #6 of 7 Old 09-05-2013, 01:22 PM
bradleybrb
1975 CJ5
My tab broke off too. I dug up the smallest screw I could find in my shop. Took a 1/16" drill bit, drilled a hole and screwed it back on there. It seems to be holding up fine that way.
bradleybrb is offline
post #7 of 7 Old 09-05-2013, 01:34 PM
2Xtreme
2Xtreme's Avatar
1979 CJ7
I did the same.
2Xtreme is offline
