Headlamp Assembly replacement - JeepForum.com
post #1 of 5 Old 07-16-2009, 09:11 AM Thread Starter
m1a1mastergunner
1979 CJ5
I was told by the parts department of the local Jeep dealer that they can only get CJ parts from the last year they were produced (1986). From looking at the parts manual of that year, the headlamp assembly looks identical. Specifically, I want to replace the stripped plastic “nut” on the housing (J812 1350, on Fig. 8-6400) to which the shell (J8121351) screws into for headlight beam adjustments. Does anyone know why this part or the entire assembly would not work on my 1979 CJ5? Currently I have just added a nut behind the plastic pieces, but I do not have enough “play” to get the headlamps adjusted properly. I have thought about shaving the plastic some, but I would prefer to replace everything. I was also hoping to find a solution cheaper than the $200 (for the pair) from a nearby Jeep supply store. My apologies if this has been answered before, I did not find the thread, and thanks in advance for any and all responses.
m1a1mastergunner is offline
post #2 of 5 Old 07-16-2009, 09:21 AM
CSP
Yes they are the same.
I believe that you can get new screws with the plastic pieces attached in the "Help" blister packs at just about any auto parts store.
CSP is offline
post #3 of 5 Old 07-16-2009, 09:31 AM
John Strenk
John Strenk's Avatar
1976 CJ5
i would think other cars and trucks would have the same simple headlight mount as the CJ.
Has anyone checked or noticed anything like that?
John Strenk is offline
post #4 of 5 Old 07-16-2009, 09:47 AM
CSP
I was thinking the same thing John. The bulbs in CJ's weren't unique at all to the CJ, so there has to be several headlight buckets out there that are also very similar, if not exact, in design.
CSP is offline
post #5 of 5 Old 07-16-2009, 09:47 AM Thread Starter
m1a1mastergunner
1979 CJ5
Thanks CSP, I never thought of checking those "help" blister packs as the other hardware is still serviceable.
Looking For A Gas Pedal Assembly? JimbtheBuilder Jeep CJ Forum 5 08-16-2009 08:33 AM
Headlamp adjusting nut Michael G Jeep CJ Forum 2 05-03-2009 02:01 PM
Weber carb air cleaner assembly replacement jennandal Jeep CJ Forum 2 09-24-2007 10:51 AM
Improved Replacement Heater Box Assembly?? magic_man1 Jeep CJ Forum 8 12-21-2006 04:14 PM
headlamp buckets liftedred84cj7 Jeep CJ Forum 9 06-05-2003 03:10 PM
