Headers! - JeepForum.com
post #1 of 8 Old 08-05-2013, 10:10 AM Thread Starter
cjlover1981
Headers!
Hey guys i need help picking some headers for my 81 cj7 with a 304 v8. I want to know whats got the best sound and what are people most happy with??
cjlover1981 is offline
post #2 of 8 Old 08-05-2013, 02:52 PM
Jeeper44mag
1978 CJ7
Still running stock here.
Luis
Black '05 LJ, soft top, ~4" lift, 42rle, 3.73, 35"x12.5" AT's, Tampa FL area
Jeeper44mag is offline
post #3 of 8 Old 08-05-2013, 10:01 PM
mattl
I've tried a couple of headers for my 360 and actually want to go back to stock. I have had issues with blown gaskets stemming from the mating surfaces not flat no matter how tight the bolts are. I also hate the rust on the 'ceramic coated' headers. It seems that it is hard to keep them rust free. I have Hedman headers now.
mattl is offline
post #4 of 8 Old 08-06-2013, 07:58 AM
Manhattan
1981 CJ8
That part about "...and what are people most happy with?", I think you'll find the answer is stock manifolds - regardless if it's an AMC or SBC, etc. I had headers on a 360 - sounded great... when the gaskets were in tact. Similar to Matt's experience, the uneven surfaces, loosening bolts... the gaskets were an issue. And yeah, rust. Unless you drop a chunk of $$$, they're going rust.
1981 CJ8, Chevy 5.7, SM465, D300, RE 4.5, 35" BFG MTs, 20/30 4.56, Detroits, Warn 9500ti
Manhattan is offline
post #5 of 8 Old 08-06-2013, 08:00 AM
CSP
The stock manifolds flow really well too. With the right muffler you can have the nice V8 rumble, if that's really what you're after going with headers.
CSP is offline
post #6 of 8 Old 08-06-2013, 08:38 AM
holliewood61
holliewood61's Avatar
1981 CJ7
I run the heddman fender exit. I took them to my local machine shop and threw them on the belt sander to even up the mounting surface. I also took a cut off wheel and sliced the bridge between 1 and 2, and between 3 and 4 so they could all pull up individual of each other. a good set of gaskets and header bolts and no leaks here. hooked on a set of cheapo glass packs. shot a coat of vht header paint (several very generous coats on the headers) and we were good to go. love the sound.
holliewood61 is offline
post #7 of 8 Old 08-06-2013, 09:39 AM
ASteve
1972 CJ5
For what it's worth...I gotta say I have had no problems with my headers. I check the bolts every now and then but that's it. I recently changed out my Hooker Headers (20+ years old) to Dougs Headers and I am very happy with them. The mufflers I have are bit loud but sound nice. With my 304 the Dougs headers have 1 5/8" primaries with 3" collectors and I reduce them down to 2.5" connection to my Flowmasters.
Doug's Headers: http://www.summitracing.com/parts/do...view/make/jeep
Also, Piercy gaskets are a must, and don't over tighten the bolts or you will mess up the header flange.
Percy's: http://www.summitracing.com/parts/ph...merican-motors
Here's a link and sound clip to my set up: http://www.jeepforum.com/forum/f8/da...l#post15241248
SC
ASteve is offline
post #8 of 8 Old 08-06-2013, 11:34 AM
mattl
Great idea about splitting the connection between pipes. I never thought about it before, but makes sense.
1986 CJ7, AMC 360, NP435, D300, Tera60 w/Detroit, D44 welded, SOA, 37" MTR
mattl is offline
