headers - Page 2 - JeepForum.com
post #16 of 32 Old 11-30-2011, 01:38 PM
I6CJ7
Heck yes! And between the long tube header and my granny gear... that thing pulls like a tractor!
That's a 600 v-twin Polaris (weigs about thr same as my CJ lol) and a few hundred pounds of camping gesr in the back of the jeep, plus the coolers and the trailer ain't no lightweight either, pulled it almost 3 hours from manassas, va to Romney, wv
I6CJ7 is offline
post #17 of 32 Old 11-30-2011, 01:53 PM
Poop3000
wish i had a picture of the two horse trailer, with two horses and a tack/dressing room in the front, that i pull to the hills with my xj.
it's about four feet taller! without the lift, it would look comical. but it tows it like a dream.
check out my sweet Hesco stroker XJ built thread, now for sale in the ad below:
http://www.jeepforum.com/forum/f153/1998-jeep-xj-cherokee-hesco-stroker-dana-super-44-lots-goodies-1290749/#post12528168
Poop3000 is offline
post #18 of 32 Old 11-30-2011, 02:19 PM
I6CJ7
Pics or it didn't happen! Lol
I6CJ7 is offline
post #19 of 32 Old 11-30-2011, 02:46 PM
Poop3000
guess it didn't.
Poop3000 is offline
post #20 of 32 Old 11-30-2011, 03:56 PM
tjd50317
Go with the one piece header. I have the 2 piece on mine and the 2 piece are a pain when in comes to exhaust. I went from a four speed to an automatic and had to redo the exhaust. It would have been a much easier job if I had the single header.
tjd50317 is offline
post #21 of 32 Old 11-30-2011, 04:26 PM
dhubing
Mine came with Hedman dual outlet headers. Was a pain to make a y-pipe... They have held up well tho, and aren't cared for at all.
dhubing is offline
post #22 of 32 Old 11-30-2011, 04:35 PM
hutch1200
Recovering Bronco Rider
hutch1200's Avatar
1979 CJ7
headers
wasn't sure if the stock manifolds until break-in comment was a question or not. i imagine it's about having that a/f ratio just right while you break in some rings and wear smooth those cylinder walls, keep the heat down and avoid a possible lean condition until a/f is dialed in. kinda like getting that carb dialed in right real fast on a new v-twin build.[/QUOTE]==poop3000
It was more of a WTF from the factory instructions.
hutch1200 is offline
post #23 of 32 Old 11-30-2011, 04:45 PM
oteps
1980 CJ5
I had a 2 piece on mine. Sounded good, I ran dual exhaust instead of a y pipe. I had to dent the one header so the clutch linkage didnt hit it. It leaked where it mounted to the head unless you used a lot of high heat rtv sealant along with the gasket.
oteps is offline
post #24 of 32 Old 11-30-2011, 05:01 PM Thread Starter
jeep670
1982 CJ8
anybody had troubles with two piece headman headers? leaks?
jeep670 is offline
post #25 of 32 Old 11-30-2011, 05:12 PM
I6CJ7
I went the single as mentioned, my brother went with the dual oulet on his just to be different, exhaust shop had difficult time making a good y-pipe for it, and his did leak at the collectors, not sure if the flange leaked though
I6CJ7 is offline
post #26 of 32 Old 11-30-2011, 05:19 PM
nicknoty
1983 CJ7
i had headmans and they warped an would never hold a seal when i had a 258.
83 cj7, white/pearl w/ black trim - 99'ax-15/clocked dana 300 twin sticked - 4"RC lift - HD shackles - 33X10.5 bfg mt's on micky' T 15" classic 2s - HD tierod flipped - custom bumpers with d-rings - winch - flowmaster - obd1 efi swap - 4.6L strocker with com smooth idle cam. soon to be:
rear disc brakes,front and rear tube fender flares and better sliders, 3.0L mercedes turbo diesel power
nicknoty is offline
post #27 of 32 Old 11-30-2011, 05:51 PM Thread Starter
jeep670
1982 CJ8
i seen a couple of cos
jeep670 is offline
post #28 of 32 Old 11-30-2011, 05:53 PM
I6CJ7
Huh, weird... I know your supposed to start with the inside bolts and work your way out, never had a problem.
I6CJ7 is offline
post #29 of 32 Old 11-30-2011, 05:58 PM
nicknoty
1983 CJ7
maybe i had a bum set but its a common problem with aftermarket header fors all vechiles. i was even using liquid copper after i happened and started retighting the manifold nuts after it heat cycled but i had nothing but problems with the header but i like the fitment on the jeep plenty of room to work on the motor mounts and the bell housing bolts
nicknoty is offline
post #30 of 32 Old 11-30-2011, 05:59 PM Thread Starter
jeep670
1982 CJ8
is that for the two piece or one piece header?
jeep670 is offline
