Head gasket failure - causes? - JeepForum.com
post #1 of 5 Old 07-09-2011, 05:11 AM Thread Starter
billybob535
I stumbled on a truck with a 401 in it. It runs but a head gasket is blown. I can change the head gaskets for about $135. What I am concerned with is what would cause the head gasket to go. If I buy it is there something to look for?
billybob535 is online now
post #2 of 5 Old 07-09-2011, 06:20 AM
gojeepin
1983 CJ7
Extreme overheating can warp a head. Putting a new gasket on it will probably not work if that's the case.
The head will have to be trued and possibly the block decked.
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #3 of 5 Old 07-09-2011, 07:56 AM
BioTex
If you remove the heads due to a blown gasket, you should have them inspected for cracks, and if none found, you should have them resurfaced.
The truck probably overheated!
'85 CJ7, BDS 4" lift, 1" Body lift, 33x12.5, Shrockworks Sliders, 304 V8 with RV cam., T-176, D300, Dana 30, AMC 20.
06' TJ Rubicon, 4" R.C. springs, BFG/AT 35s M.C. 6" fenders, rockers and surrounds, Currie front & rear adj. tracbars, tattons DC rear shaft, adj. upper - lower CA's. Bilstein 5100's
Current project. Stroker/FI ?
1990 MJ Comanche 4.0L AX15/np231
BioTex is offline
post #4 of 5 Old 07-09-2011, 06:04 PM Thread Starter
billybob535
Thanks for the info. I was too slow and missed out on it.
post #5 of 5 Old 07-09-2011, 07:04 PM
mopar408
1974 CJ5
cross your fingers it's a gasket and not a cracked head.
401 head? ouch!
If it's good TO you, it's gotta be good FOR you....
mopar408 is offline
Head Gasket bad? The Keith Jeep CJ Forum 2 12-14-2008 06:52 PM
Head Gasket ? drunkenrich Jeep CJ Forum 2 04-18-2008 09:23 AM
head gasket!!!! shelbycj5 Jeep CJ Forum 4 10-31-2007 11:47 PM
head gasket fun Lethander Jeep CJ Forum 0 09-03-2007 06:12 PM
Head Gasket dana60cj Jeep CJ Forum 2 04-11-2003 03:36 PM
