!!! head gasket blown help!!!!!!! - JeepForum.com
post #1 of 3 Old 12-21-2009, 05:30 PM Thread Starter
afgd1
other day blew head gasket crap! was running great too now what new engine or pray its not hurt any body have a motor? well take a part to night hope head is okay help what to
okay so got engine apart guess whatno # 2 piston its gone well any body got an engine what year can i go up to with out to many problems !!!!
afgd1 is offline
post #2 of 3 Old 12-22-2009, 08:59 AM
JeepHammer
Running On Empty...
1973 CJ5
Head gaskets need a reason to give way.
How long has the 'Coolant' been in without flush and replacment?
Coolant goes acidic when you leave it in too long and will compromised the head gasket, along with things like water pump, thermostat, radiator.
Have you overheated the vehicle lately?
Overheat will expand the head bolts to the point the gasket can fail and will progressively will get worse.
Is your distributor set in the correct position?
One tooth forward will fire two cylinders at once in the firing order, and the second cylinder will fire 90 degrees too soon, hammering the head gasket out.
This takes time, you can run MONTHS with an advanced distributor before this happens...
If you have a HEI distributor, many of them are WAY too far advanced when you are under load, and that will hammer a head gasket out over time.
Some times you have those old head gaskets, and they just rot out after 25+ years of abuse!
I've seen the steel shim gaskets rust out,
The fiber gaskets rot out,
The only one that doesn't give up easily is Fel-Pro 'Blue' gaskets with the stainless steel 'O' ring at the cylinder.
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #3 of 3 Old 12-23-2009, 08:34 AM Thread Starter
afgd1
head gasket
thanks for info when we flushed rad and system put new pump rad and thremostat one odd thing is thermostat was 165 oem is 195 put in 195 2 weeks later head gasket went but gauge alwasy was at 165 when old one and 195 when new never got hot
afgd1 is offline
How do I diagnose a blown head gasket? imtheant Jeep CJ Forum 19 11-26-2013 09:34 AM
Blown Head Gasket? Cpolinsky Jeep CJ Forum 0 01-22-2010 05:22 AM
cj7 304 v8 blown head gasket thegrand Jeep CJ Forum 2 09-30-2009 08:42 PM
Blown head gasket? again! trueprimitive Jeep CJ Forum 5 09-29-2009 12:30 AM
Blown head gasket on 258 I6? SuB8HaVeN Jeep CJ Forum 7 01-07-2008 02:16 PM
