HD Steering Solutions??? - JeepForum.com
post #1 of 14 Old 12-20-2007, 06:58 AM Thread Starter
sanmiam
sanmiam's Avatar
1983 CJ7
Looking to upgrade the steering components during the build and was looking for an HD drag link/tie rod manufacturer. The truck is definately going to be seeing some moderate off-roading (depending on what you definition is - we're talking rocks, not fire trails) and am quite sure the 20+ year old soda straws that AMC used for steering linkage will not work. Pretty much the only manufacturer I have found in Big Daddy, but was looking for some additional options. If you have a HD kit lying around I would be interested in that too. Thanks.
sanmiam is offline
post #2 of 14 Old 12-20-2007, 07:30 AM
aero mech
aero mech's Avatar
1980 CJ7
You can purchase them at 4wd or quadretec. Just looked at them this mourning. IIRC 4wd have their own brand also.JC
80 CJ-7 Straight six,comp cam,4.0 head, cherokee header, DUI distributor, Affordable FI TBI ,4.10's wide track amc 20 aussie locked and trussed, Dana 30 aussie locked, PSC steering box, 4.5 RE lift, twin sticked dana 300 with Lo max 4to1 35"STT'S ON DC-1 "It's getting there"
aero mech is offline
post #3 of 14 Old 12-20-2007, 07:31 AM
aero mech
aero mech's Avatar
1980 CJ7
Did a quick search, Tellico, and Rugged ridge also offer the HD tie rods. JC
post #4 of 14 Old 12-20-2007, 07:39 AM
YeloCJ
[IMG][/IMG][IMG][/IMG]
I built this set up for my CJ-7, I reinforced the pitman arm with 1/4" plate all around it and I built the tie rod and draglink out of 1.5 O.D. chrome-moly, using 1 ton tie rod ends.
YeloCJ, 360, 36's and Detroits f/r, T-18, Tera-low 20
YeloCJ is offline
post #5 of 14 Old 12-20-2007, 08:22 AM
Happy Joe
Very nice!
I have done similar links using 1" x1/4 wall dom Heavier than stock but not as beefy as 1.5 molly.
Just get some heavy wall tube, cut it to length and get it bored and threaded at your local machine shop. Heavier ends need their tapered holes reamed to a larger size.
... much cheaper than kits.
Enjoy!
...a well prepped, well driven, vehicle should do well in any terrain, including the highway.
Carburetors became obsolete during the last century... do what ever it takes to get fuel injection...It makes bigger grins off road.
Happy Joe is offline
post #6 of 14 Old 12-20-2007, 08:35 AM
dirtman13
dirtman13's Avatar
2007 CJ7
I installed the ones from MORE. I do a little more then moderate offroading and they preform flawlessly.
http://www.mountainoffroad.com/more.htm
dirtman13 is offline
post #7 of 14 Old 12-20-2007, 08:49 AM Thread Starter
sanmiam
sanmiam's Avatar
1983 CJ7
Originally Posted by Happy Joe
Very nice!
Enjoy!
Hmmmm, Never thought of this, not sure why. I think I may give this option a whirl.... Sent you a PM re: the taper necessary to fit larger ends.
sanmiam is offline
post #8 of 14 Old 12-20-2007, 09:30 AM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
I got these from Jim's Off Road on Ebay.
They are huge. Come with the tie rod ends, too.
Can't beat 145 bucks for them, either. They come in wide or narrow track.
Pacfanweb is offline
post #9 of 14 Old 12-20-2007, 03:55 PM
JeepHammer
Running On Empty...
1973 CJ5
Someone REALLY didn't want that pitman arm to do anything stupid!
Here is a tip for you...
I got tired of having to play 'Strigent the drag link' every time we went out, so I did about the same thing the guy in the picture did, Heavy wall tubing...
Also made my Hi-Lift handle into a drag link replacement...
You know, Murphy's law, if you have a spare, it won't happen anymore!...
And it hasn't! Haven't bent a drag link in the past two years now that I'm ready for the darn thing!
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #10 of 14 Old 12-20-2007, 08:13 PM
smokedog
www.searchers4wd.com
They will custom build you. Their steering kits are around $300 (drag link, tie rod all with Heim joints). I just purchased mine from them based on a referral and have been pleased with their service. Just another resource... Hope it helps.
Smokedog - Brandon, MS
84' CJ7 Renegade - Tungsten grey metallic paint, 388ci Chevy, 700r4, D300, SOA lift with YJ springs, 1" body lift, Bilstein 5150 shocks, Currie Rock Crawler Shackles, Trussed Ford 9 Rear w/ 4:56 gears, Detroit lockers, Dana 44 front, full poison spyder cage and lots of chrome and stainless.
smokedog is offline
post #11 of 14 Old 12-20-2007, 10:23 PM
Mr.Crowley
Mr.Crowley's Avatar
1980 CJ7
when measuring dom or other tubing for tie rods or drag links,do you recomend cutting to length so the rod end is about at the half way point of the threads?Most likely going this rout and using heim's
1980 cj7 258 weber,5'' of lift,33'' boggers,lincoln locked,lockright and a snorkle...Khaki Jeep Club member No. 1
1984 cj8 350 on 35's..the wifes
Originally Posted by Me
"offroad it, and wave then you might understand"
BLS Home Chapter... Where it all Started
:hahaha: yj
My low Buck Rock Crawler project Project..Stop by and check it out..
Mr.Crowley is offline
post #12 of 14 Old 12-21-2007, 08:59 AM
Happy Joe
Yep! But verify the toe in and readjust it (if necessary) before measuring as a badly bent tie rod can affect it.
I don't recommend heims for stearing (expecially the cheap summit heims) as they seem prone to contamination induced wear on a friend's rig. They are right out front in the dirt, snow, ice, sand, salt, weather. I used heavier tie rod ends and did a flip (requies a tapered reamer) at the same time (no issues since), they were cheaper than quality heims (free.. I had them on hand) and replacements will be availiable in any town with a parts store.
Enjoy!
post #13 of 14 Old 12-21-2007, 03:30 PM
Mr.Crowley
Mr.Crowley's Avatar
1980 CJ7
Ya know what Happy Joe, I did not think about out of town replacements..Good point..Im going with 3/4 ton axles and a high steer set up..So one ton tre's should be the way to go..I did the tre flip on my one cj and it worked perfectly..
:hahaha: yj
post #14 of 14 Old 12-21-2007, 08:59 PM
solitudetree
There are many options out there if you look. JP magazine did the Big Daddy kit on one of their project vehicles. I think it was Project Hatari (CJ6 rebuild).
They said it went on easy and was a very good product for the price.
All the Jeeps I've owned
79 CJ5 258 six with a weber (current vehicle) T18/Dana20
81 CJ5 258 six (driven out of Alaska thru Canada in winter with a softtop)
75 Jeep Wagoneer 360V8
79 Jeep Cherokee 258 six
solitudetree is offline
CJ Gun Storage Solutions? cfljeep Jeep CJ Forum 15 03-28-2017 05:42 PM
air in cooling system solutions? rodjr Jeep CJ Forum 10 05-14-2009 07:31 PM
Spare Tire Solutions White92 Jeep CJ Forum 8 04-25-2008 10:00 AM
Child Seat Solutions? Knight6 Jeep CJ Forum 4 01-30-2005 01:44 PM
A/C solutions pf1130 Jeep CJ Forum 7 08-16-2004 09:05 PM
