HD Steering Shaft w/ U-joint Options - JeepForum.com
post #1 of 9 Old 04-18-2014, 09:55 PM Thread Starter
burley
1976 CJ5
I'm trying to get rid of some play in the coupler north of the steering box. I would love to get the Borgeson and be done, but I'm already over budget and have another kid on the way, due in a few months.
I've been doing lots of searching and cant seem to find much of a comparison between the (double U-joint) Crown and Omix-ADA. Each can be found for around $130, which is $80 cheaper than the Borgeson.
On a side note, is there any way to tighten up the OEM bell coupler? I took it apart and I don't understand where it wears out and gets loose. Its all metal, and I didn't notice any obvious wearing or gashes.
Thanks,
burley is offline
post #2 of 9 Old 04-19-2014, 05:50 AM
jp360cj
1977 CJ7
You can replace the bell coupler for about $40-$45. No experience with the HD shafts, so can't comment on that.
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline
post #3 of 9 Old 04-19-2014, 06:13 AM
1949er
The kit num. is 998710k
1949er is offline
post #4 of 9 Old 04-19-2014, 08:25 AM Thread Starter
burley
1976 CJ5
I guess that brings me back to wondering why it fails to begin with. If I throw $40 at it I want to make sure it helps. I thought the bell coupler has play in it brand new. Correct me if I'm wrong. I tore mine apart and I don't understand what is wearing in the bell coupler. Is there supposed to be a little play in the upper u-joint as well?
burley is offline
post #5 of 9 Old 04-19-2014, 08:38 AM
CSP
Parts that rub against each other do wear each other out. The rubbing slowly eats away at the material. The square pieces rub at the pins they sit on and the pins get smaller and the holes in the square parts get larger just for an example.
Remember, your '76 CJ is almost 40 years old.
CSP is offline
post #6 of 9 Old 04-19-2014, 08:53 AM
jeepwhore
There was a thread on here earlier in the week where people were complaining about the crown shafts and their lack of quality and durability....FWIW.
Is an extra $80 really too much to spend on one of the most important systems on your Jeep? Given Crown and Omix's reputations for sub par parts I personally wouldn't (and didn't) risk it. I got the Borgeson and am extremely happy with it.
Steering and brakes are the 2 things I refuse to cheap out on and in my opinion crown is no better than junkyard parts in most cases. More than likely the replacement coupler will come from either crown or omix, so you'd be flushing $40 down the crapper that could have gone towards the Borgeson.
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #7 of 9 Old 04-19-2014, 08:59 AM Thread Starter
burley
1976 CJ5
I found the Borgeson for $200 shipped from Mudflaps.com. I think I'll do that route and save running the risk of blowing $40 on parts that do no good.
Thanks for the input and "steering" me in the right direction.
burley is offline
post #8 of 9 Old 04-19-2014, 09:10 AM
1949er
If you have play in the upper joint - non serviceable - get a new shaft
1949er is offline
post #9 of 9 Old 04-19-2014, 09:13 AM
Redmanchew
Redmanchew's Avatar
1982 CJ7
x2
1982 CJ-7 2003 4.3 chevy vortec, 4L60E, Clocked Dana 300 35 x 12.5 x 15 KM2 on Cragar 399's. Vanco Brake Booster. Power steering conversion. Warn front and rear bumpers with swing away. Moser 1 piece rears. Rear OX.
Support your local MS foundation. You don't know how much this disease sucks until it affects someone you love.
Originally Posted by twoleos617 View Post
To reiterate for the 1,067th time, when towing...
remove rear axle, xfer in N, trans in 5th, remove neg batt cable, key to Run and go??
Redmanchew is offline
