Having trouble getting spare key made for 85 CJ7 - JeepForum.com
post #1 of 20 Old 06-05-2014, 06:23 AM Thread Starter
Joncure
I have tried several places to get a spare key made for my 85 CJ7 with no luck. The places I have gone to don't have the mold/template for the key. I only have the one key and need a couple spares.
Oddly, the key that I have is a GM key.
Ideas? Suggestions?
Joncure is offline
post #2 of 20 Old 06-05-2014, 06:29 AM
Shenandoah
I can check the local hardware store in Waynesboro, VA. I'm pretty sure that is where me spares were made. It's an Ace Hardware, lots of them around.
Turn a wrench, save a tree
Shenandoah is offline
post #3 of 20 Old 06-05-2014, 06:31 AM Thread Starter
Joncure
Thanks Shenandoah.
I haven't checked ACE yet and there are couple here in Lexington.
Joncure is offline
post #4 of 20 Old 06-05-2014, 10:15 AM
Boomer
1982 CJ8
Have you tried an actual locksmith?
Boomer is offline
post #5 of 20 Old 06-05-2014, 10:25 AM
LumpyGrits
Got mine at Lowe's
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #6 of 20 Old 06-05-2014, 11:10 AM
cmsurfer
Originally Posted by LumpyGrits View Post
Got mine at Lowe's
LG
Ditto....
I either got mine at Home Depot or Lowes for my '85. They had trouble finding a matching blank, but was able to look in their book and find a matching one from another AMC vehicle.
cmsurfer is offline
post #7 of 20 Old 06-05-2014, 11:10 AM
Mike Romain
They are GM keys because GM uses the same steering column as the CJ's.
Mike
Mike Romain is offline
post #8 of 20 Old 06-05-2014, 11:27 AM
Texjeep84
I have a 84 cj and had 4 keys made at home depot, all 4 worked perfect.
Texjeep84 is offline
post #9 of 20 Old 06-05-2014, 07:39 PM
only in a jeep cj
85 and 86 used GM keys. The 84 back was different.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #10 of 20 Old 06-05-2014, 09:53 PM
BlkCJ7Laredo
BlkCJ7Laredo's Avatar
1984 and older is a RA4 blank, 85-86 is a RA5 blank, which is the same as a GM "J" blank.
'85 CJ-7 Laredo currently under construction.
BlkCJ7Laredo is offline
post #11 of 20 Old 06-05-2014, 10:08 PM
capt205
1983 CJ7
My 83 is a GM key.
capt205 is offline
post #12 of 20 Old 06-05-2014, 10:10 PM
only in a jeep cj
Then it could have been swapped as the key cylinders are interchangeable in those GM later columns. All 84 and back ORIGINAL keys Ive ever seen have not been the GM "J" type, but the regular older key that is very different in cut and shape than the later keys. Instead of fitting just the ignition, the older ones fit doors too.
Ed
1975 CJ-6 1983 CJ-8
post #13 of 20 Old 06-05-2014, 10:36 PM
CSP
Just because they aren't a J blank doesn't mean they aren't the same as a GM key. GM keys changed over the years as well.
CSP is online now
post #14 of 20 Old 06-06-2014, 03:47 AM
RWise
1981 CJ5
My 81 takes a GM key as well.
RWise is offline
post #15 of 20 Old 06-06-2014, 05:32 AM
Mike Romain
They still used the GM Saginaw column back into the late 70's didn't they?
Mike
