have you ever broken a drive shaft? - JeepForum.com
post #1 of 6 Old 09-18-2011, 01:38 PM Thread Starter
jm708
2014 JK Wrangler
I would like to know if any of you have broken a drive shaft, front or rear (not U-joints). Can you tell me what mods you were running and what you were doing when it happened? As always pics are always cool.
Thanks Justin
jm708 is offline
post #2 of 6 Old 09-18-2011, 04:25 PM
Stumpbumper
Rears in a couple jeeps! A 74 CJ with a Lincoln locker , 304 and T19.
Seen lots of twists and bent ones in my time! Usually due to lead footing it, or gaining traction at a high throttle situation.
1984 CJ7, 258..HEI..MC2100, T176/D300, D30/M20 lockers, lift, warn winch!
"When in doubt! Gas it out!"
Stumpbumper is offline
post #3 of 6 Old 09-18-2011, 04:41 PM
nshefbuch
1982 CJ7
Snapped mine on the road just hitting the gas to hard. Later I snapped an axle same way. Now running full widths so this doesn't happen anymore. My setup should be listed below on my post. Basically sum it up is built 360 + stock axles and shafts = not so well.
CJ7/SOA YJ leaf/5.3LS/t18a/d300 clock/37"Pitbull Rockers/H1's/14 bolt/d44 ARB 4.10 High Steer
nshefbuch is offline
post #4 of 6 Old 09-18-2011, 05:13 PM
78FordF150
1983 CJ7
I have broken several. But the most memorable was a front shaft. Got cocky one night after I was the only who could make it up a hill at the river. So I told them I could make it up backwards. Needless to say I didn't make it.
To much weight transfer and power on a tiny front shaft.
78FordF150 is offline
post #5 of 6 Old 09-19-2011, 12:11 AM Thread Starter
jm708
2014 JK Wrangler
Anyone else? I just think it seems you would break a U-joint before the shaft would give in. Well here is hoping mine holds out for a while.
jm708 is offline
post #6 of 6 Old 09-19-2011, 04:30 AM
nshefbuch
1982 CJ7
A stock shaft will break first over a u joint. Stock shafts are around .065 thick with small diameter where my aftermarkets are .120 and larger diameter.
Grand Cherokee Drive shaft/CV Shaft jollyroger Jeep CJ Forum 5 12-13-2011 05:31 PM
broken yoke on drive shaft arkiemurph Jeep CJ Forum 0 09-27-2010 11:48 AM
uh okay a little help please; arm on my choke shaft was broken off njdave Jeep CJ Forum 5 07-26-2010 09:49 AM
Broken shaft that connects shift lever to T/C darwood112 Jeep CJ Forum 1 05-27-2008 04:16 PM
Broken Drive shaft bluecj Jeep CJ Forum 4 08-01-2005 09:05 AM
