-   -   have a carter 2bl on my I258 need replacement! (http://www.jeepforum.com/forum/f8/have-carter-2bl-my-i258-need-replacement-1359627/)
thetripster 04-21-2012 08:55 PM
I have an 81 Cj5 with the AMC 258 and i have and idle problem and my mechanic buddy says i need to rebuild or replace the carb. So what i'm saying is i need to replace it and i was just wondering what everyone has to offer in opinions. I kind of want to stay with Double Barrel so suggested ideas???:2thumbsup:
thetripster 04-21-2012 08:57 PM
Its a carter 2681 by the way. i forgot to mention:shhh:
Chuckles0227 04-21-2012 09:06 PM
Motorcraft 2100/2150 swap, its easy to do and works much better than the carter
thetripster 04-21-2012 09:20 PM
is there somewhere that sells the whole conversion kit? i was reading over some stuff and it says theres a few things you need.
Bojon 04-21-2012 09:36 PM
I've got a couple of 2150's I'm trying to get rid of. I also have my old carter with a fresh rebuild
Chuckles0227 04-21-2012 09:43 PM
You can get the kit on ebay its like 300 some but he includes everything, or you can go to a junkyard find an 80's ford with a 302 pull the carb, rebuild it get the adapter from autozone, and fab a throttle cable support. The later would probably be cheaper if you don't count your time as money.
Bojon-
Are they 1.08's and is there much play In the throttle shafts?
If they're good to go I may want one. I kinda broke an ear off mine and have it held together with jbweld. What would you want for one?
Bojon 04-21-2012 09:59 PM
Bojon-
Yeah, they are 1.08's, and the throttle shafts feel tight. I'm looking for $50 plus shipping, I know it seems a little high, but I can drive 20 minutes down the road and get the same for them. I'd rather see someone on the forum get them though.
EveryDayCJ 04-21-2012 11:52 PM
I might be the only person still happy with my Carter, I clean the feeder tubes maybe once a year... 165,000, still going. Perhaps you've already tried this? Good Luck!
http://www.jeeptech.com/engine/carter.html
Mickey_Mouse 04-22-2012 01:01 AM
I recieved my carb from this guy five years ago:
http://www.ebay.com/itm/MotorCraft-2...item3374c57c0b
better throttle response and gas milage
Slydeco 04-22-2012 05:30 AM
Carter :thumbsup:
pman 04-22-2012 07:05 AM
4 Attachment(s)
Tripster-
The idle tubes on the Carter have holes that are known for clogging, and cause fuel to "drip" from them causing the poor idle issue. Sadly, most mechanics don't know this and recommend replacement or rebuild, when in actuality it's a 10 minute fix that doesn't require removal of the carb.
I highly recommend checking out the link that EveryDayCJ posted to see if that's your problem.
You can have the tubes drilled out which will lessen the chance of them clogging again.
The Motorcraft 2100/2150 is a very popular upgrade. If I ever needed to replace my Carter I'd personally go that route.
mylittlecj5 04-22-2012 07:39 AM
I've got a brand new EMPI Weber 32/38 conversion carb KIT sitting here I'd like see go to a good home...Pm me if your interested in it.
Matt_G 04-22-2012 11:13 AM
12 Attachment(s)
I just bit the bullet and bought the $300 kit off ebay. brand new mc2100, manual choke and the filter kit. I was tired of messing with the carter and if the mpg gains are as good as he says they are I will be happy. i'll let you know how it goes as soon as I get it and install it.
Chuckles0227 04-22-2012 11:16 AM
Ill let you know if I want one, a salvage yard here will make you pay at least 50 so not a bad price. I may have one back home now off a 304 but im not sure quite yet.
thetripster 04-22-2012 05:31 PM
i just ordered the weber 32/36 but i am going to keep my carter and do the idle tube thing. theres a couple guys around me that love their webers and its a real simple bolt on so wish me the best!
The time now is 01:23 PM.
