Hasselback's "Lets try this again" CJ7 build - Page 6 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Hasselback's "Lets try this again" CJ7 build
Zone Offroad Body and Suspension Lift Kits, Brackets, DiscJeep Wrangler Framless, Bowless, Trektops 92-95 YJ, 97-06 Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 01-21-2013, 10:28 PM   #76
MrBeast
1980 CJ7
Originally Posted by hasselback View Post
And this is the Jeep that I spent over 2 years building, and then only 2 days tearing back down to use for parts on my new build! Makes me sad
Maybe I missed something but why did you have to tear it down?
[I]"He used to be a pretty nice feller, now he's a welder"[/I]
[URL="http://www.jeepforum.com/forum/f22/1980-cj7-first-jeep-build-1243620/"]80 CJ7 "The Kraken" - a project 25 years in the making[/URL] AMC 304 V8, NV4500, Dana 300, Dana 44, 9 inch, M.O.R.E. SRS, YJ tub.
AT3 US Navy 1999-2003
[B][SIZE="3"] Cum catapultae proscriptae erunt tum soli proscript catapultas habebunt[/SIZE][/B]
[SIZE="1"](When catapults are outlawed, only outlaws will have catapults)[/SIZE]
MrBeast is offline   Reply With Quote Quick reply to this message
Unread 01-21-2013, 10:51 PM   #77
skizriz
1978 CJ7
Because he's smarter than I am.
78 CJ7.. 258.. TH400/Dana18.. SOA/stock YJ springs.. 35" General Grabbers.. Waggy 44s.. 4.88 gears...Spartan/Lockright...Fiberglass front to rear
skizriz is offline   Reply With Quote Quick reply to this message
Unread 01-22-2013, 05:16 AM   #78
hasselback
Read post #1. I didn't have to. But with everything I learned by reading this forum, it made me want to start over and do it right. My original project started with just replacing a pinion bearing in the rear end, and before you know it, the whole jeeps stripped down to the frame. Prior to that, the biggest mechanical fix I had done was change my brakes!
hasselback is offline   Reply With Quote Quick reply to this message
Unread 01-22-2013, 05:46 AM   #79
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Hassel,
Do you think that pipe bender would handle a roll cage project, using the same diameter pipe as the factory roll bar (1-1/2"...?)?
Thanks,
Matt
Matt1981CJ7 is online now   Reply With Quote Quick reply to this message
Unread 01-22-2013, 07:27 AM   #80
hasselback
Originally Posted by Matt1981CJ7 View Post
Hassel,
Thanks,
Matt
I doubt it. Harbor Freight has a bigger bender thats 16 tons which might do it. I haven't tried 1 1/2 pipe in mine yet.
Unread 01-22-2013, 11:38 AM   #81
Skerr
Hassel,
Thanks,
Matt
Matt... my .02...
When we built Clay's cage I tried very hard to use that specific bender on 1 1/2" welded tubing. It's not DOM, but it IS tubing. There was commentary about using black iron pipe for the cage, but it was finally decided that you lack some structural integrity as compared to using tubing. That bender is a pipe bender, and it will bend it all day. But it DOES NOT bend tubing worth a crap! I watched all the YT videos I could of how "others" CAN do it, even with packing the tubing with sand to prevent it from crushing, but it was an absolute failure. I ended buying the prebent A and B pillars and then welded up straight pieces for cage support/bracing.
A TUBING BENDER is around $300, and EACH individual die is another $300. I couldn't justify the cost, so I bought prebent...
HF does not sell a tubing bender. Only a pipe bender. A 12 ton jack will bend your angles in 1 1/2" tubing or pipe. The HF pipe bender will kink your tubing.
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 01-22-2013, 04:39 PM   #82
Matt1981CJ7
1981 CJ7
Hassel and Scott,
Thanks. I have no experience bending pipe or tube (other than when I don't want to, like on a plumbing project ) So that's all good info to know.
It sounds like pre-bent is the way to go.
Matt
Unread 01-22-2013, 06:17 PM   #83
Skerr
Hassel and Scott,
Matt
I bought from this guy, and have nothing but good to say about him. His name is Mike, and he is the owner. Bender is CNC...
www.extremecustomfab.com
Kerrdog
Go Fish! <*////><
Unread 01-26-2013, 01:23 PM   #84
hasselback
Got my mufflers in the mail last night, so I got to work on the exhaust today. Also got the Dana300 put back in, and the rear driveshaft. I moved the engine forward about an inch and a half to give me good clearance at the firewall, and now my shaft seems to be extended all the way. Will this be ok? Or should I look into getting a longer shaft?
1984 CJ7 I6 258 Bone stock
"[I]Screw the brakes, just make the horn louder[/I]!"
My build thread
[url]http://www.jeepforum.com/forum/f8/hasselbacks-lets-try-again-cj7-build-1409432/[/url]
Unread 01-26-2013, 01:46 PM   #85
jeepwhore
I'd wait and see what it does after you get the weight of the tub/roll bar/interior put back on. Right now your rear suspension is only compressed by the weight of the frame which isn't much at all. Once you get closer to full assembly look at the rear driveline again and see if it will work . But something tells me if it's maxed out right now it's going to give you headaches when the suspension is at full extension regardless of how much weight is on there.
'84 CJ-7: Yota axles (spartan locked front, e-locked rear) 4" BDS, 1" Daystar & 3/8" shackle lifts, 35" X-Terrains on steelies, YJ Tub & family roll bar, heater blower upgrade, 4.2L w/MC2100 & Team Rush, Warn 8274. Rebuilt 4.2/4.0 hybrid, AX15 and twin sticks/clocking ring waiting to go in.
The advertised position for a topless, dirty jeep girl has been filled......by my wife. Thanks to all that applied.
<------------and yes, that is her.
:-D
jeepwhore is offline   Reply With Quote Quick reply to this message
Unread 01-27-2013, 10:05 AM   #86
Skerr
^^ Yep, do the shaft last or close to last. It has to slip in and out depending on the action of the axle. If it is bottomed-out and you hit a hole there is no travel left.
Question... what was the reason to move the engine forward, and do you have good clearance for the radiator? No insult intented, but in my own working plane I seem to do everything twice!
Kerrdog
Go Fish! <*////><
Unread 01-27-2013, 11:58 AM   #87
hasselback
Theres still some movement left in the driveshaft, just not as much as before. And, last time I had the jeep together, the motor was rubbing the firewall slightly, so If I was going to relocate it, I wanted to make sure I had plenty of clearance. I had several inches between the fan and radiator.
Unread 01-30-2013, 09:29 PM   #88
Skerr
Thinking back to my driveshaft... IIRC, the DS has about 3 inches of total travel. You want to set it up so there is an inch and half of travel in either direction. Maybe I'm not remembering this exactly right, but I think I am. If you need some specific detail I can measure our spare. I can't say that reducing travel in one direction by 1/2" is bad, but there is surely some number where you reach that point of diminishing return! I'm sure driving style would have a major impact.
Kerrdog
Go Fish! <*////><
Unread 01-31-2013, 12:34 PM   #89
hasselback
I remembered I had a spare driveshaft that I bought when I thought I lost my original (turned up in the garage shortly after I bought it's replacement), and i measured it. Looks like I should have enough play left in it afterall.
I ran my fuel lines and the rear brake line last night, and will get some pics of that up Saturday. I hope to get the chassis all done this weekend, so I can get the tub back on. All I need to do to the tub is scrape off all the junk undercoating that I sprayed on the underside 2 years ago, and replace it with bedliner, then it can go back on. I think I can see the light at the end of the tunnel already
Unread 01-31-2013, 06:59 PM   #90
skizriz
1978 CJ7
If that's the same stuff as on the frame, the good news is that a wire wheel strips it off easily, the bad news is that you will end up wearing all of it.
You're coming down the home stretch now. Looks good.
