Hasselback's "Lets try this again" CJ7 build - Page 37 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Hasselback's "Lets try this again" CJ7 build
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 11-08-2013, 10:41 AM   #541
Renegade82
Renegade82's Avatar
1982 CJ7
Sounds like a better deal anyways. You can sometimes haggle with these guys and get free shipping even when they're not running a free shipping special.
Skiz - you seem to keep an eye on CL for stuff, let me know if you ever run across any blue denim seats or seat covers.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
http://www.jeepforum.com/forum/f8/30...e-off-1280850/
Renegade82 is offline   Reply With Quote Quick reply to this message
Unread 11-08-2013, 11:22 AM   #542
skizriz
1978 CJ7
Will do.
Sent from my HTC One SV using JeepForum
78 CJ7.. 258.. TH400/Dana18.. SOA/stock YJ springs.. 35" General Grabbers.. Waggy 44s.. 4.88 gears...Spartan/Lockright...Fiberglass front to rear
skizriz is offline   Reply With Quote Quick reply to this message
Unread 11-08-2013, 01:57 PM   #543
hasselback
Also got a new windshield frame and cowl seal today from Morris. Also free shipping!
1984 CJ7 I6 258 Bone stock
"[I]Screw the brakes, just make the horn louder[/I]!"
My build thread
[url]http://www.jeepforum.com/forum/f8/hasselbacks-lets-try-again-cj7-build-1409432/[/url]
hasselback is offline   Reply With Quote Quick reply to this message
Unread 11-10-2013, 12:43 PM   #544
hasselback
Went back out to do some more body work this morning, but ran out of welding wire, so I decided to switch gears and start dropping the suspension out in preparation for my lift kit which will be here on Wednesday. So I got the jeep up on jack stands, and cut into the rear crossmember to spray some penetrating oil on the bolts holding the shackle mounts on. I have a new crossmember to go in also, so I'll tackle that now too. 3 out of 4 bolts came right out, and the bolt that snapped, that nutsert popped out when I was banging on it! I'm still amazed at how good of shape the frame is in here! Below, you can see how much dirt I got out of the inside of the frame!
My build thread
Unread 11-10-2013, 01:18 PM   #545
hasselback
I've got everything disconnected on the rear end, just gotta pull the bolts out of the spring hangers, and I can roll it out. Only problem is, they won't budge! They won't even turn, and I've almost mushroomed the end of the bolts pounding on them with a sledge! I've had to burn out rubber bushings before, and it looks like I'll be doing it again, once I get a new tank for the torch!
My build thread
Unread 11-10-2013, 02:21 PM   #546
skizriz
1978 CJ7
I've had good luck squeezing a cutoff Wheel in between the spring eye and hanger to cut the bolts.
Always a PITA no matter how you do it.
Unread 11-10-2013, 05:10 PM   #547
hasselback
Well I took your advise Steve, and this is what happened!
On the plus side though, I kept my garage from filling up with black smoke! It's out though.....
My build thread
Unread 11-10-2013, 05:17 PM   #548
hasselback
I can't stand this coating that is all over everything, but it sure saved everything it was on! Got bright shiny metal as you can see on the rear axle! I've noticed it melts off easily with a little heat, so the rear end will get cleaned up And painted with Por before it goes back in.
My build thread
Unread 11-10-2013, 05:29 PM   #549
skizriz
1978 CJ7
Looks about the same as every time I have done it too. I guess I should have mentioned that part also...
J/K, glad you didn't hurt yourself too bad. I've done that with a knotted wire wheel a few times. That usually takes awhile to heal.
What is the black stuff? Some type of tar?
Unread 11-10-2013, 05:47 PM   #550
hasselback
It sure seems like tar. It has the consistency of roofing tar. It's certainly not regular undercoating. It's kind of like pulling a well preserved saber toothed tiger out of a tar pit!
My build thread
Unread 11-10-2013, 09:46 PM   #551
lucdog
lucdog's Avatar
1980 CJ5
I would guess undercoating. The PO of one of my jeeps put it inside the tub, gasoline was the only thing I found that would remove it.
Nasty stuff for sure. Possibly Ziebart also.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is online now   Reply With Quote Quick reply to this message
Unread 11-11-2013, 06:30 AM   #552
ScroungerLee
I have heard of people using roofing tar as undercoating. It sure looks like you have a messy job ahead of you.
ScroungerLee is offline   Reply With Quote Quick reply to this message
Unread 11-11-2013, 08:52 AM   #553
Renegade82
Renegade82's Avatar
1982 CJ7
After my undercoating had pealed and flaked away I was left with a brown colored flakey, powdery substance!! But not to fret. I threw some dry sand at it really fast and hard and it took it right off.
Unread 11-11-2013, 01:26 PM   #554
hasselback
What I got is so thick and gooey that you could throw gravel at it at warp speed, and it would probably just absorb into it and become part of the coating!
My build thread
Unread 11-11-2013, 04:01 PM   #555
hasselback
Now that was some quick shipping! Awesome kit too. Even got degree shims! Now I got lots of work to do. Who wants to come help??
My build thread
