Hasselback's "Lets try this again" CJ7 build - Page 34 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Hasselback's "Lets try this again" CJ7 build
WIN a set of Mammoth Boulder Wheels at ExtremeTerrain.com!Truck & Jeep Fest 2015 - EdmontonFS: Wrangler RGB Multicolor Fog Light LEDs: Awesome Effect
Unread 10-28-2013, 07:51 PM   #496
sireland67
You can buy the 1/4 panels cheaper than you can make them.
These are made Detroit, good heavy steel, have used their repair panels on a couple of projects.
http://c2cfabrication.com/store/adva..._description=1
sireland67 is offline   Reply With Quote Quick reply to this message
Unread 10-29-2013, 06:13 AM   #497
hasselback
Thanks for the link. I made my quarter panel for $39.99, so that was a better deal for me. But I see they sell windshield frames for only $106.00. I do need one of those too, and will probably get it from them. Beats $154 at Morris!
1984 CJ7 I6 258 Bone stock
"[I]Screw the brakes, just make the horn louder[/I]!"
My build thread
[url]http://www.jeepforum.com/forum/f8/hasselbacks-lets-try-again-cj7-build-1409432/[/url]
hasselback is offline   Reply With Quote Quick reply to this message
Unread 10-29-2013, 07:32 AM   #498
ScroungerLee
Nice bushing set, it looks almost like someone handed you an envelope of cash for new toys! Are you going to do all the bushings now?
ScroungerLee is offline   Reply With Quote Quick reply to this message
Unread 10-29-2013, 09:58 AM   #499
hasselback
They all went up on the shelf for now. I'll use them up as I take things apart here and there. I'll probably start with the suspension. I plan on ordering a 2.5 inch lift (part number TM3625-20012) from 4WD.com. I really do need new leaf springs, and new shocks, and new U bolts, so for $389, I might as well get the whole kit, and get the minimal lift that I want to use 32 inch tires. I've decided this will be my ONLY modification over stock.
For the body mounts, I'm going to try to raise the tub just enough to swap them out, and change out all the brake lines at the same time. The more I think about it, and after putting some miles on it already, I don't think I want to do a ground up restoration on it. It really doesn't need it. I believe I can fix the bad and turn it back into a beautiful CJ without turning it into a pile of parts first! I really like the idea of having an "all original", and rebuilding it I believe takes that away.
So, what I'm looking at now is:
Fix all the body rot (in progress now)
Strip off black paint, repaint red (original color)
Fix and replace worn mechanical parts (brake lines, transfer case)
Raptor line inside of tub (tinted red)
Replace worn seals and gaskets on doors and hard top
Replace or repair windshield frame
Replace rear crossmember and gas tank skid plate
New seats
Re-chrome or paint original wagon wheels
Replace all bushings
Replace worn leaf springs with 2.5 inch lift springs
That's it! That should keep me busy for the winter...
My build thread
Unread 10-29-2013, 10:10 AM   #500
Renegade82
Renegade82's Avatar
1982 CJ7
Yes, that was the 3M brushable seam sealer I used. Strong odor to it.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (still in progress....)
http://www.jeepforum.com/forum/f8/30...e-off-1280850/
Renegade82 is offline   Reply With Quote Quick reply to this message
Unread 10-29-2013, 10:42 AM   #501
ScroungerLee
Yeah it does sound like you will be busy all winter . Sounds like it will come out nice.
Unread 10-29-2013, 11:31 AM   #502
hasselback
Originally Posted by Renegade82 View Post
What, you don't believe me??
My build thread
Unread 10-29-2013, 04:58 PM   #503
hasselback
Leaves got mad and headed down to see Skizriz today, so I had some time to work in the shop. All I did though was cut down my new panel to fit. It's ready to be welded in tomorrow. Maybe by this weekend it will be done, and I can move on to the next spot under the door. Not sure what's under that patch, but it's not all the way through!
My build thread
Unread 10-30-2013, 05:48 PM   #504
hasselback
Spot weld after spot weld, my biggest repair is finally finished! Stuck a straight edge across it, and I shouldn't need very much filler. I'm satisfied with the way it turned out! Once I'm done patching, I'll go back and sand blast the primer off and brush on some Por-15 before I start with the filler.
My build thread
Unread 10-30-2013, 07:01 PM   #505
skizriz
1978 CJ7
Nice work. :-)
Sent from my HTC One SV using JeepForum
78 CJ7.. 258.. TH400/Dana18.. SOA/stock YJ springs.. 35" General Grabbers.. Waggy 44s.. 4.88 gears...Spartan/Lockright...Fiberglass front to rear
skizriz is offline   Reply With Quote Quick reply to this message
Unread 10-31-2013, 06:03 AM   #506
hasselback
Originally Posted by skizriz View Post
Nice work. :-)
Thanks! I feel like I need a vacation before i start on the next patch!
My build thread
Unread 10-31-2013, 06:41 AM   #507
ScroungerLee
That looks very nice. What kind of sandblaster do you have?
Unread 10-31-2013, 07:49 AM   #508
hasselback
Thanks. It's a cheap one from Tractor Supply. holds like 3 bags of sand.
My build thread
Unread 10-31-2013, 10:22 AM   #509
Renegade82
Renegade82's Avatar
1982 CJ7
Looks factory new!
Unread 10-31-2013, 12:17 PM   #510
seabass1858
seabass1858's Avatar
1983 CJ7
1 word, flawless. I would not have the patience nor the ability with my medical condition (I shake too much)
seabass1858 is offline   Reply With Quote Quick reply to this message
