Hasselback's "Lets try this again" CJ7 build - Page 8 - JeepForum.com
 3Likes
post #106 of 853 Old 02-14-2013, 02:11 PM Thread Starter
hasselback
Originally Posted by Renegade82 View Post
You may have read that on my build thread. However, I first heated it with a propane torch and scraped the heavy stuff off with a putty knife. Then the remnants wiped off easily with some WD-40. I never tried spraying the heavy stuff from the start so it may / may not work. Eastwood does make some spray stuff specifically for removing undercoating but I never tried that.
Thanks, I think it was your thread. I'll try the torch method. then WD40. It hasn't been on there for very long, so hopefully it will come off easy.
hasselback is offline
post #107 of 853 Old 02-14-2013, 08:41 PM Thread Starter
hasselback
I realized today that it's alot easier to work on the firewall when you can stand right in front of, so I got it painted, and started mounting everything to it.
1984 CJ7 I6 258 Bone stock
"Screw the brakes, just make the horn louder!"
My build thread
post #108 of 853 Old 02-15-2013, 08:19 AM Thread Starter
hasselback
Alright, I need everyone's opinion. I'm shopping for new wheels, and am torn between these two. I'll be painting the jeep Malibu Sunset Metallic Orange, pretty close to the color of my motor pictured in previous posts. All my trim will be black, so I wanted black wheels too. Might even do an orange pinstripe on the wheels. I'm leaning towards the Pro Comp wheels since my tires and shocks are all Pro Comp too. Plus, they are on sale now at 4WD.com. I can get a set of 5 delivered to my door for less than $500. Only problem is, they only have them in 15x10. My tires are on 8 inch wide rims now. Without running home to look at them, I believe they are either 10.5 or 11.5 inches wide. Will this work?
The Black Rock wheels are the right size, but more money of course. Gimme your opinions!
post #109 of 853 Old 02-15-2013, 08:45 AM
CJ7ROB
I'd go with the first ones in 10", your tires definitely look like 11.5s. Wider rims always look better IMO. You should try searching CL for those rims if you can, otherwise if you don't want to wait I'd say yea pull the trigger on them.
CJ7ROB is offline
post #110 of 853 Old 02-15-2013, 09:05 AM Thread Starter
hasselback
Are those 10 inch wide rims on your Jeep? I was just looking at my tires on Quadratec, They are Pro Comp Mud Terrains. I know they are 33's on 15 inch rims. The only width they come in on that size is actually 12.5. I don't want to wait, But I should probably wait until I get home at least to make sure my tires are wide enough. I think $465 delivered is a smokin deal for 5 alloy wheels! Now I just need to find something to do here at work so I don't go pullin the trigger just yet!
post #111 of 853 Old 02-15-2013, 09:41 AM
CJ7ROB
Yea mine are 10s with 35x12.5s. I had 33x12.5s on the same rims but 8" and they just looked too tucked in.
CJ7ROB is offline
post #112 of 853 Old 02-15-2013, 09:54 AM Thread Starter
hasselback
Thanks! you just helped me make up my mind...
post #113 of 853 Old 02-15-2013, 10:10 AM
Renegade82
1982 CJ7
I don't like black rims at all. Makes them looked like spares or just spray painted black. But maybe that's just me. To each his own. On the rim size I'd go with 8" ones. The 10" rims tend to make your tires look fatter rather than taller. Now if your jumping up to 35" tires which are usually close to 14" wide, then yes go with 10" rims. Again, IMO.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #114 of 853 Old 02-15-2013, 10:47 AM Thread Starter
hasselback
I actually was going to just spraypaint the chrome rims I have now, but didn't want it to look cheesy. The other issue is, I only have the 4 rims, but I have 5 tires, so I'd have to try to find a matching rim for the spare. Also, I won't have any chrome anywhere else on the Jeep, so I think chrome rims would stick out like a sore thumb, IMO. This pic is a Volkswagen Beetle done by Chip Foose, and this is the color scheme I'm going with. Two tone orange and black.
post #115 of 853 Old 02-15-2013, 01:57 PM
2girlsAndaGuy
1979 CJ5
foose is the man, and that color combination is SWEET!!!
David
2girlsAndaGuy is offline
post #116 of 853 Old 02-15-2013, 02:55 PM Thread Starter
hasselback
Thanks, and with the $2000 per gallon pricetag for that exact paint, I'll be going just a shade off probably!
post #117 of 853 Old 02-15-2013, 02:57 PM Thread Starter
hasselback
And I'd like to see Foose do a CJ7. Can't even imagine what it would turn out like!
post #118 of 853 Old 02-15-2013, 03:08 PM
Renegade82
1982 CJ7
See, I don't mind them when they're glossy and have other colors or chrome with them. But just flat black, nah, not for me.
post #119 of 853 Old 02-15-2013, 04:42 PM Thread Starter
hasselback
I like the looks of the orange pinstripe around the wheel. I plan on doing that with mine once I get them. That should make it stand out just enough.
post #120 of 853 Old 02-16-2013, 11:58 AM Thread Starter
hasselback
I sold my old cloth seats out of the jeep for 150.00 for the pair a few days ago, and headed down to the junkyard today to look for some nice leather seats. Found this pair out of a 94 blazer for only 100 bucks! So I went back out in the yard and found an underhood retractable light from a 92 GMC truck, and a lighted rear view mirror out of a Trans-Am. I figured the lights under the mirror will work great as a dome light, since I dont plan on running a top. I got the metal piece that glues to the windshield too, but will probably weld that to a bracket that I can bolt to the windshield frame. Ill probably mount the retractable light in the cab somewhere, since it has enough wire to wrap around the jeep twice!
My build thread
"Gaucho" CJ stepside pickup build jscherb Jeep CJ Forum 1449 11-15-2016 04:17 PM
BUILD THREAD: Project "Ghetto Fabulous" motiv8ya Jeep CJ Forum 799 06-19-2015 06:28 PM
Justins "Civillian Jeep" Build nacheswheelin Jeep CJ Forum 47 01-03-2013 10:36 PM
1985 "Special Edition" CJ7 Restoration Build Thread elliottferrell Jeep CJ Forum 38 07-23-2012 10:09 AM
1979 CJ7 "Spartan" Build Report Jmaas Jeep CJ Forum 20 01-09-2009 09:14 PM
