Hasselback's "Lets try this again" CJ7 build - Page 37 - JeepForum.com
 3Likes
post #541 of 853 Old 11-08-2013, 09:41 AM
Renegade82
1982 CJ7
Sounds like a better deal anyways. You can sometimes haggle with these guys and get free shipping even when they're not running a free shipping special.
Skiz - you seem to keep an eye on CL for stuff, let me know if you ever run across any blue denim seats or seat covers.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #542 of 853 Old 11-08-2013, 10:22 AM
skizriz
1978 CJ7
Will do.
Sent from my HTC One SV using JeepForum
skizriz is offline
post #543 of 853 Old 11-08-2013, 12:57 PM Thread Starter
hasselback
Also got a new windshield frame and cowl seal today from Morris. Also free shipping!
1984 CJ7 I6 258 Bone stock
"Screw the brakes, just make the horn louder!"
My build thread
hasselback is offline
post #544 of 853 Old 11-10-2013, 11:43 AM Thread Starter
hasselback
Went back out to do some more body work this morning, but ran out of welding wire, so I decided to switch gears and start dropping the suspension out in preparation for my lift kit which will be here on Wednesday. So I got the jeep up on jack stands, and cut into the rear crossmember to spray some penetrating oil on the bolts holding the shackle mounts on. I have a new crossmember to go in also, so I'll tackle that now too. 3 out of 4 bolts came right out, and the bolt that snapped, that nutsert popped out when I was banging on it! I'm still amazed at how good of shape the frame is in here! Below, you can see how much dirt I got out of the inside of the frame!
My build thread
post #545 of 853 Old 11-10-2013, 12:18 PM Thread Starter
hasselback
I've got everything disconnected on the rear end, just gotta pull the bolts out of the spring hangers, and I can roll it out. Only problem is, they won't budge! They won't even turn, and I've almost mushroomed the end of the bolts pounding on them with a sledge! I've had to burn out rubber bushings before, and it looks like I'll be doing it again, once I get a new tank for the torch!
My build thread
post #546 of 853 Old 11-10-2013, 01:21 PM
skizriz
1978 CJ7
I've had good luck squeezing a cutoff Wheel in between the spring eye and hanger to cut the bolts.
Always a PITA no matter how you do it.
skizriz is offline
post #547 of 853 Old 11-10-2013, 04:10 PM Thread Starter
hasselback
Well I took your advise Steve, and this is what happened!
On the plus side though, I kept my garage from filling up with black smoke! It's out though.....
My build thread
post #548 of 853 Old 11-10-2013, 04:17 PM Thread Starter
hasselback
I can't stand this coating that is all over everything, but it sure saved everything it was on! Got bright shiny metal as you can see on the rear axle! I've noticed it melts off easily with a little heat, so the rear end will get cleaned up And painted with Por before it goes back in.
My build thread
post #549 of 853 Old 11-10-2013, 04:29 PM
skizriz
1978 CJ7
Looks about the same as every time I have done it too. I guess I should have mentioned that part also...
J/K, glad you didn't hurt yourself too bad. I've done that with a knotted wire wheel a few times. That usually takes awhile to heal.
What is the black stuff? Some type of tar?
skizriz is offline
post #550 of 853 Old 11-10-2013, 04:47 PM Thread Starter
hasselback
It sure seems like tar. It has the consistency of roofing tar. It's certainly not regular undercoating. It's kind of like pulling a well preserved saber toothed tiger out of a tar pit!
My build thread
post #551 of 853 Old 11-10-2013, 08:46 PM
lucdog
lucdog's Avatar
1980 CJ5
I would guess undercoating. The PO of one of my jeeps put it inside the tub, gasoline was the only thing I found that would remove it.
Nasty stuff for sure. Possibly Ziebart also.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #552 of 853 Old 11-11-2013, 05:30 AM
ScroungerLee
I have heard of people using roofing tar as undercoating. It sure looks like you have a messy job ahead of you.
ScroungerLee is offline
post #553 of 853 Old 11-11-2013, 07:52 AM
Renegade82
1982 CJ7
After my undercoating had pealed and flaked away I was left with a brown colored flakey, powdery substance!! But not to fret. I threw some dry sand at it really fast and hard and it took it right off.
post #554 of 853 Old 11-11-2013, 12:26 PM Thread Starter
hasselback
What I got is so thick and gooey that you could throw gravel at it at warp speed, and it would probably just absorb into it and become part of the coating!
My build thread
post #555 of 853 Old 11-11-2013, 03:01 PM Thread Starter
hasselback
Now that was some quick shipping! Awesome kit too. Even got degree shims! Now I got lots of work to do. Who wants to come help??
My build thread
BUILD THREAD: Project "Ghetto Fabulous" motiv8ya Jeep CJ Forum 804 06-11-2017 03:57 PM
"Gaucho" CJ stepside pickup build jscherb Jeep CJ Forum 1449 11-15-2016 03:17 PM
Justins "Civillian Jeep" Build nacheswheelin Jeep CJ Forum 47 01-03-2013 09:36 PM
1985 "Special Edition" CJ7 Restoration Build Thread elliottferrell Jeep CJ Forum 38 07-23-2012 09:09 AM
1979 CJ7 "Spartan" Build Report Jmaas Jeep CJ Forum 20 01-09-2009 08:14 PM
