Hasselback's "Lets try this again" CJ7 build - Page 34 - JeepForum.com
post #496 of 822 Old 10-28-2013, 07:51 PM
sireland67
You can buy the 1/4 panels cheaper than you can make them.
These are made Detroit, good heavy steel, have used their repair panels on a couple of projects.
http://c2cfabrication.com/store/adva..._description=1
sireland67 is offline
post #497 of 822 Old 10-29-2013, 06:13 AM Thread Starter
hasselback
Thanks for the link. I made my quarter panel for $39.99, so that was a better deal for me. But I see they sell windshield frames for only $106.00. I do need one of those too, and will probably get it from them. Beats $154 at Morris!
1984 CJ7 I6 258 Bone stock
"Screw the brakes, just make the horn louder!"
My build thread
http://www.jeepforum.com/forum/f8/ha...build-1409432/
hasselback is offline
post #498 of 822 Old 10-29-2013, 07:32 AM
ScroungerLee
Nice bushing set, it looks almost like someone handed you an envelope of cash for new toys! Are you going to do all the bushings now?
ScroungerLee is offline
post #499 of 822 Old 10-29-2013, 09:58 AM Thread Starter
hasselback
They all went up on the shelf for now. I'll use them up as I take things apart here and there. I'll probably start with the suspension. I plan on ordering a 2.5 inch lift (part number TM3625-20012) from 4WD.com. I really do need new leaf springs, and new shocks, and new U bolts, so for $389, I might as well get the whole kit, and get the minimal lift that I want to use 32 inch tires. I've decided this will be my ONLY modification over stock.
For the body mounts, I'm going to try to raise the tub just enough to swap them out, and change out all the brake lines at the same time. The more I think about it, and after putting some miles on it already, I don't think I want to do a ground up restoration on it. It really doesn't need it. I believe I can fix the bad and turn it back into a beautiful CJ without turning it into a pile of parts first! I really like the idea of having an "all original", and rebuilding it I believe takes that away.
So, what I'm looking at now is:
Fix all the body rot (in progress now)
Strip off black paint, repaint red (original color)
Fix and replace worn mechanical parts (brake lines, transfer case)
Raptor line inside of tub (tinted red)
Replace worn seals and gaskets on doors and hard top
Replace or repair windshield frame
Replace rear crossmember and gas tank skid plate
New seats
Re-chrome or paint original wagon wheels
Replace all bushings
Replace worn leaf springs with 2.5 inch lift springs
That's it! That should keep me busy for the winter...
My build thread
post #500 of 822 Old 10-29-2013, 10:10 AM
Renegade82
1982 CJ7
Yes, that was the 3M brushable seam sealer I used. Strong odor to it.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
http://www.jeepforum.com/forum/f8/30...e-off-1280850/
Renegade82 is offline
post #501 of 822 Old 10-29-2013, 10:42 AM
ScroungerLee
Yeah it does sound like you will be busy all winter . Sounds like it will come out nice.
post #502 of 822 Old 10-29-2013, 11:31 AM Thread Starter
hasselback
Originally Posted by Renegade82 View Post
What, you don't believe me??
My build thread
post #503 of 822 Old 10-29-2013, 04:58 PM Thread Starter
hasselback
Leaves got mad and headed down to see Skizriz today, so I had some time to work in the shop. All I did though was cut down my new panel to fit. It's ready to be welded in tomorrow. Maybe by this weekend it will be done, and I can move on to the next spot under the door. Not sure what's under that patch, but it's not all the way through!
My build thread
post #504 of 822 Old 10-30-2013, 05:48 PM Thread Starter
hasselback
Spot weld after spot weld, my biggest repair is finally finished! Stuck a straight edge across it, and I shouldn't need very much filler. I'm satisfied with the way it turned out! Once I'm done patching, I'll go back and sand blast the primer off and brush on some Por-15 before I start with the filler.
My build thread
post #505 of 822 Old 10-30-2013, 07:01 PM
skizriz
1978 CJ7
Nice work. :-)
Sent from my HTC One SV using JeepForum
skizriz is online now
post #506 of 822 Old 10-31-2013, 06:03 AM Thread Starter
hasselback
Originally Posted by skizriz View Post
Nice work. :-)
Thanks! I feel like I need a vacation before i start on the next patch!
My build thread
post #507 of 822 Old 10-31-2013, 06:41 AM
ScroungerLee
That looks very nice. What kind of sandblaster do you have?
post #508 of 822 Old 10-31-2013, 07:49 AM Thread Starter
hasselback
Thanks. It's a cheap one from Tractor Supply. holds like 3 bags of sand.
My build thread
post #509 of 822 Old 10-31-2013, 10:22 AM
Renegade82
1982 CJ7
Looks factory new!
post #510 of 822 Old 10-31-2013, 12:17 PM
seabass1858
1983 CJ7
1 word, flawless. I would not have the patience nor the ability with my medical condition (I shake too much)
seabass1858 is offline
"Gaucho" CJ stepside pickup build jscherb Jeep CJ Forum 1447 04-10-2016 04:32 PM
BUILD THREAD: Project "Ghetto Fabulous" motiv8ya Jeep CJ Forum 799 06-19-2015 05:28 PM
Justins "Civillian Jeep" Build nacheswheelin Jeep CJ Forum 47 01-03-2013 09:36 PM
1985 "Special Edition" CJ7 Restoration Build Thread elliottferrell Jeep CJ Forum 38 07-23-2012 09:09 AM
1979 CJ7 "Spartan" Build Report Jmaas Jeep CJ Forum 20 01-09-2009 08:14 PM
