Hasselback's "Lets try this again" CJ7 build - Page 32 - JeepForum.com
 3Likes
post #466 of 853 Old 10-22-2013, 07:22 PM
seabass1858
1983 CJ7
I did a nutter. heres a detailed explination of the vaccumline routing i used and it works great. no oil blowby, i advanced the timing 8 degreese btdc. heres a detailed reply i did for a guy with pics http://www.jeepforum.com/forum/f8/ol...85/index8.html post 110. I did a team rush using the original ign system and used a carb rebuild kit that came with the jeep and no issues at all with the original carter bbd. Make sure the stepper pin is 1/8th where you can see the shoulder.
seabass1858 is offline
post #467 of 853 Old 10-23-2013, 06:07 PM Thread Starter
hasselback
Thanks for the link to the write up. Should come in handy when I go to do the nutter bypass.
Last time I was under the Jeep, I noticed the rear pumpkin cover had two little rust holes in the top. So I pulled it off, expecting to see either water or mud inside, but was surprised to see it was still full of clean looking oil! Also saw these numbers painted on the pinion gear. Do they have any relation to my gear ratio?
Back to my holy cover though, my solution to the holes was to weld a drain plug over the hole, and weld up the other small hole. I couldn't upload a pic of the finished product though. Turned out good, and now I can easily drain the oil. Might add a fill plug at the top too.
1984 CJ7 I6 258 Bone stock
"Screw the brakes, just make the horn louder!"
My build thread
hasselback is offline
post #468 of 853 Old 10-23-2013, 06:38 PM
seabass1858
1983 CJ7
Thats pennsylvania for you. You should see what my willys floor looks like. (Swiss Cheese)
post #469 of 853 Old 10-23-2013, 06:50 PM
skizriz
1978 CJ7
The numbers you see on the pinion are for the factory setup I believe.
For the ratio,there will be numbers stamped on the ring gear.
Enter them here.
http://www.ringpinion.com/calculators/Calc_GR.aspx
skizriz is offline
post #470 of 853 Old 10-23-2013, 06:58 PM Thread Starter
hasselback
I seem to remember someone saying to count the teeth on each gear, and divide them to get the ratio. The numbers painted on are 42 and 13, and it looks like there is 13 teeth on the pinion. That would make it 3:23 gear ratio. Never heard of that one before.......
My build thread
post #471 of 853 Old 10-23-2013, 07:12 PM
seabass1858
1983 CJ7
3.31 soundls like it fits the bill which is a factory ratio
post #472 of 853 Old 10-24-2013, 11:37 AM Thread Starter
hasselback
Here's a pic of the cover with the drain plug installed.....
My build thread
post #473 of 853 Old 10-25-2013, 09:17 AM Thread Starter
hasselback
Picked up some 16 gauge steel today to start fabricating the new wheel well arch. Gonna have to make it in three pieces, but I got my fingers crossed! The left side is still good, so I'm going to trace it on a sheet of plywood to use as a form to make for the new piece. I'd be diving into that project tonight if I wasn't heading to camp tonight for a day of hunting tomorrow. Half of me wants to stay home and do this though!
My build thread
post #474 of 853 Old 10-25-2013, 11:22 AM
ScroungerLee
I am looking forward to seeing the metal work! Amazing that the diff cover rusted all the way through, but strange things happen on jeeps I guess. The rear diff on mine has a hose sticking out where the fill plug should be, who knows what that's about LOL.
ScroungerLee is offline
post #475 of 853 Old 10-25-2013, 12:05 PM Thread Starter
hasselback
Thats your vent tube!
My build thread
post #476 of 853 Old 10-25-2013, 12:55 PM
bradleybrb
1975 CJ5
Been a while since I have checked in. Looks good. You should be able to do this one with your eyes closed!
bradleybrb is offline
post #477 of 853 Old 10-25-2013, 01:29 PM
Renegade82
1982 CJ7
Tell me about it! These Jeep builds play hell on your hunting season. It's hard to focus on anything else without wishing you were getting some work done on your build. I normally take off today for the early ML season and hunt today and tomorrow, but instead I'm at home taking care of some outside winterizing tasks (it's my lunch break) because my weekends are usually spent on the Jeep. Playin' catch-up! I couldn't skin up a deer right now without major re-arrangement unless I do it outside.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #478 of 853 Old 10-25-2013, 02:05 PM Thread Starter
hasselback
Originally Posted by Renegade82
Tell me about it! These Jeep builds play hell on your hunting season. I couldn't skin up a deer right now without major re-arrangement unless I do it outside.
I hear ya! Last year I had to do my skinning outside because I had a non rolling jeep parked under my hoist! That's not the case this year
My build thread
post #479 of 853 Old 10-26-2013, 03:56 PM Thread Starter
hasselback
Was just looking at the original owners manual that was in the glove box, and was amused at this page. They must know that I spend more time under my jeep than in it. Those jacks can give way at any time!
My build thread
post #480 of 853 Old 10-26-2013, 04:07 PM
ScroungerLee
"Stay calm and be reassuring to the victim". Sounds like something every CJ owners wife should be taught to do!
"Gaucho" CJ stepside pickup build jscherb Jeep CJ Forum 1449 11-15-2016 03:17 PM
BUILD THREAD: Project "Ghetto Fabulous" motiv8ya Jeep CJ Forum 799 06-19-2015 05:28 PM
Justins "Civillian Jeep" Build nacheswheelin Jeep CJ Forum 47 01-03-2013 09:36 PM
1985 "Special Edition" CJ7 Restoration Build Thread elliottferrell Jeep CJ Forum 38 07-23-2012 09:09 AM
1979 CJ7 "Spartan" Build Report Jmaas Jeep CJ Forum 20 01-09-2009 08:14 PM
