Hasselback's "Lets try this again" CJ7 build - Page 30 - JeepForum.com
 3Likes
post #436 of 853 Old 10-17-2013, 02:08 PM
ScroungerLee
ScroungerLee is offline
post #437 of 853 Old 10-17-2013, 06:35 PM Thread Starter
hasselback
Well I dove into the rear breaks tonight with the intention of replacing both wheel cylinders, but once I got in there, I realized they were actually in good shape, along with all the other parts in there! The bleeders even came loose without a fight. While I was messing with the right side is when I found my leak though. Brake line corroded through right at the cylinder. Ran and got another, and put it in only to realize the line coming back to the rear end also had a hole in it. Going to try to splice a new chunk of brake line in there tomorrow. seeing that really made me want to start restoring it now, but I pulled myself together, and decided to keep putting band aids on it, and at the same time, start stockpiling parts that I will need for the resto. Once I have everything I need, then I'll start the frame off. With my antique registration, I don't need to worry about it not passing inspection at least!
1984 CJ7 I6 258 Bone stock
"Screw the brakes, just make the horn louder!"
My build thread
hasselback is offline
post #438 of 853 Old 10-18-2013, 06:11 AM Thread Starter
hasselback
Just got an Email from PayPal saying my $102.00 payment to Classic Enterprises for my wheel well repair panel was refunded!?!
Never even heard from them, other than a receipt. I guess they feel I can do better by making it myself, which I shall do now!
post #439 of 853 Old 10-18-2013, 07:15 AM
ScroungerLee
Better a refund than an unexpected charge!
post #440 of 853 Old 10-18-2013, 09:36 AM Thread Starter
hasselback
Thats right! Took that money and ordered a Prothane master bushing kit to replace all the 30 year old bushings in this thing. Won't use them all right away, but I'll have them all once I really get going on the rebuild.
I also found a good gas tank skid plate, and transmission skid plate in my inventory of spare parts, both of which need replaced on the new Jeep. So I'll sand blast them, POR-15 them, and put them up on the shelf waiting with the rest of my parts. New fuel line came already, and I'm going to have to find a new windshield frame, brake line kit, and some other odds and ends before I dive in too deep.
Since I plan to keep this mostly stock, and I'm starting out with a complete vehicle with almost everything in working order, my parts list is quite smaller compared to the last build! This restoration is going to be more like take everything apart, clean and paint, and reassemble!
post #441 of 853 Old 10-18-2013, 10:55 AM
ScroungerLee
Find any bump stops?
Edit: I am (mostly!) just teasing you, if you don't have them I will just buy some. I imagine the bolts are broken off in the frame which is why they didn't get back on. No big deal.
post #442 of 853 Old 10-18-2013, 12:44 PM Thread Starter
hasselback
Haven't had a chance to look for them yet, Tomorrow is garage cleaning day. And no bolts were broke off in the frame. If one wouldn't come out, or broke off, I welded a stud on top of it, and heated it up cherry red and got it out. So new bump stops will go right in.
post #443 of 853 Old 10-18-2013, 02:23 PM
ScroungerLee
Cool, thanks. I didn't mean any offense about broken bolts.
post #444 of 853 Old 10-18-2013, 03:53 PM Thread Starter
hasselback
Here's my last band aid on the braking system. Holding good, and she stops on a dime now. Brake light even went off. Now, on to the next project!
My build thread
post #445 of 853 Old 10-18-2013, 05:16 PM Thread Starter
hasselback
Is it bad when you've memorized your credit card number from buying so many Jeep parts online??
My build thread
post #446 of 853 Old 10-18-2013, 05:24 PM
skizriz
1978 CJ7
It's even worse when the guys working at the local Advance Auto have it memorized.
Or an order for anything other than Jeep parts gets you a call from the bank for suspected credit card fraud....
.......And the wife tells them they can keep it because they spend less than you do.....
skizriz is offline
post #447 of 853 Old 10-18-2013, 05:25 PM
EgulAye
1980 CJ5
Hasselback, those look like the compression sleeve type fittings. Are they? If. So, they aren't suitable / rated for brake systems. For brakes you should use a double flare tool and flared fittings.
2012 JK
Do you wave at night when they can't see you?
EgulAye is offline
post #448 of 853 Old 10-18-2013, 06:16 PM Thread Starter
hasselback
I know they're not the "proper" fittings, but like I said, it's just a band aid, not a permanent fix. Everything brake related will get replaced with SS lines when I do the resto.
My build thread
post #449 of 853 Old 10-19-2013, 07:32 PM Thread Starter
hasselback
All I did to the jeep today was drive it a bit. Spent the bulk of the day cleaning and organizing the shop, and built some shelves for all the parts. It's amazing how much more room I got now! I think I even wore out my helper!
My build thread
post #450 of 853 Old 10-20-2013, 05:11 AM
EgulAye
1980 CJ5
The shop looks nice, time well spent
2012 JK
EgulAye is offline
"Gaucho" CJ stepside pickup build jscherb Jeep CJ Forum 1449 11-15-2016 03:17 PM
BUILD THREAD: Project "Ghetto Fabulous" motiv8ya Jeep CJ Forum 799 06-19-2015 05:28 PM
Justins "Civillian Jeep" Build nacheswheelin Jeep CJ Forum 47 01-03-2013 09:36 PM
1985 "Special Edition" CJ7 Restoration Build Thread elliottferrell Jeep CJ Forum 38 07-23-2012 09:09 AM
1979 CJ7 "Spartan" Build Report Jmaas Jeep CJ Forum 20 01-09-2009 08:14 PM
