Hasselback's "Lets try this again" CJ7 build - Page 22 - JeepForum.com
 3Likes
post #316 of 853 Old 06-14-2013, 03:20 PM
lucdog
lucdog's Avatar
1980 CJ5
Of my factory gauge showed that hot on my 304 I'd pull over and check things over.
My first suspicion would be the aftermarket speedo cluster/gauge, if that's what you have.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #317 of 853 Old 06-14-2013, 04:09 PM Thread Starter
hasselback
The speedo cluster is original, just the fuel and temp gauges are new from crown. I also got a mechanical gauge coming off the other side of the intake, which isn't registering anything. It's weird!
1984 CJ7 I6 258 Bone stock
"Screw the brakes, just make the horn louder!"
My build thread
hasselback is offline
post #318 of 853 Old 06-14-2013, 04:58 PM
lucdog
lucdog's Avatar
1980 CJ5
Did you put the mech. Gauge in a intake runner?
I should have been more specific regarding the cluster. 198* I don't think would be to warm either.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #319 of 853 Old 06-14-2013, 05:08 PM Thread Starter
hasselback
The mech gauge has been in the same hole for ever, one of the thermal vacuum switch holes, and it did work, and always ran 195 to 198. For some reason though it just quit. There's no calibration to a new electric temp gauge is there?
My build thread
post #320 of 853 Old 06-14-2013, 05:13 PM
lucdog
lucdog's Avatar
1980 CJ5
Probably no calibration. Except bending the needle. You might send a PM to John S. and ask him.
Ha, just like everything else, things wear out.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #321 of 853 Old 06-14-2013, 05:38 PM Thread Starter
hasselback
This is what it's at after running for 15 minutes. The new electric gauge went up like in the last pic, and held there. Didn't get any hotter. I pulled the radiator cap right after I shut it off, and there was no pressure behind it though.
My build thread
post #322 of 853 Old 06-14-2013, 07:16 PM Thread Starter
hasselback
Well I took it for for a 2 mile ride up the road and back, got it up to 35 MPH, and the temp never got any hotter, plus, I put about 3 gallons of gas in it, and the gas needle moved, but just up to empty. Might have to bend the needles a little bit??
I also started painting the hood tonight. Gonna get that put on tomorrow, as well as the rear bumper and tire carrier, so at least cosmetically, it will look done!
My build thread
post #323 of 853 Old 06-14-2013, 07:55 PM Thread Starter
hasselback
Originally Posted by hasselback View Post
Got the temp gauge working, but I'm concerned I'm running a little hot, or is that needle position normal for a 360? I stuck a thermometer in the radiator after I shut it off, and it was at 198 degrees.
And technically, It's between the two lines, still in the green area, so it should be good, right?
post #324 of 853 Old 06-14-2013, 08:06 PM
lucdog
lucdog's Avatar
1980 CJ5
I should have answered your question better. No, that is not the normal position for any Jeep engine. Be it a I6 or a 401.
My only concern on the needle position would be how much higher is the sweep of the needle, if it does overheat.
I also have to think the electric sending units are going to be the same between a I6 and a V8. I doubt AMC put a different gauge in the speedo cluster, if they came with a 4,6 or 8 cyl.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #325 of 853 Old 06-14-2013, 08:31 PM Thread Starter
hasselback
Thermostats are cheap enough, so I think I'll start there, even though I replaced it already last year sometime. The water in the radiator still was only at 185 at the warmest though.
My build thread
post #326 of 853 Old 06-14-2013, 08:39 PM
lucdog
lucdog's Avatar
1980 CJ5
I'm not a fan of replacing parts that are working. I would replace the Mech. gauge thou. If you do replace the thermostat, put in a failsafe one.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #327 of 853 Old 06-14-2013, 08:57 PM Thread Starter
hasselback
I'm planning on doing away with the mech gauge, that's why I'm trying to get the electric one working and reliable.
My build thread
post #328 of 853 Old 06-14-2013, 09:18 PM
lucdog
lucdog's Avatar
1980 CJ5
O
For what it's worth, the factory gauge in my DD 304 runs a little to the right of center. I did think of a possible problem with bending the needle. Somewhere in the gauge there is most likely a stop, maybe a pin or something similar. If this is the case, It may not peg the needle if the engine overheats.
Before I changed anything I would find out how the sensor in the manifold works, I'm sure there is a way to check them.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #329 of 853 Old 06-15-2013, 05:02 AM Thread Starter
hasselback
Might try pulling the sensor out, attaching a ground wire around it, then sticking it in a pot of boiling water to see if that pegs out the gauge.
My build thread
post #330 of 853 Old 06-16-2013, 04:50 PM
titanjeep
1980 CJ5
Got some brand new furniture for the Jeep today. Got the front seats installed, but for some reason the passenger seat sits a little higher than the drivers seat, and I can't figure out why, and it's driving me nuts now! All I can think of is that I don't have sliders under the drivers side?
Those are nice looking seats. What brand are they?
Air Force Jeep Club - Tail# JF183RV
2003 KJ
1980 CJ5
1988 Wagoneer
titanjeep is offline
BUILD THREAD: Project "Ghetto Fabulous" motiv8ya Jeep CJ Forum 804 06-11-2017 03:57 PM
"Gaucho" CJ stepside pickup build jscherb Jeep CJ Forum 1449 11-15-2016 03:17 PM
Justins "Civillian Jeep" Build nacheswheelin Jeep CJ Forum 47 01-03-2013 09:36 PM
1985 "Special Edition" CJ7 Restoration Build Thread elliottferrell Jeep CJ Forum 38 07-23-2012 09:09 AM
1979 CJ7 "Spartan" Build Report Jmaas Jeep CJ Forum 20 01-09-2009 08:14 PM
