Hasselback's "Lets try this again" CJ7 build - Page 13 - JeepForum.com
 3Likes
post #181 of 853 Old 03-23-2013, 11:24 PM
popascj7
1976 CJ7
If you use that filter before the pump and have it hooked up to the fuel return you'll be sucking air.
popascj7 is offline
post #182 of 853 Old 03-24-2013, 12:14 AM
Crisco87
1977 CJ7
I know during my teardown, the fuel filter was right about where you have it in the picture - after the fuel pump.
Crisco87 is offline
post #183 of 853 Old 03-24-2013, 07:29 AM Thread Starter
hasselback
Thanks, I didn't think about that, but it makes sense. This filter doesn't seem to have an in and out labeled. Does it matter?
hasselback is offline
post #184 of 853 Old 03-30-2013, 03:49 PM
MrBeast
1980 CJ7
Originally Posted by hasselback View Post
Well, its after 11pm, and I just came in from the garage! Got a bunch of little things Crossed off the list tonight. Started by getting the rest of the body bolts in. It only took a 2 ton come along hooked to the frame and a piece of angle that I had to bolt to the tub where the fender bolts up. Took a few cranks to pull everything into alignment, but I got it. Went from that, to reinstalling the shifters.
Attachment 592282
Attachment 592283
Then I threw in the front driveshaft, but i got to get some new straps and bolts. Cant seem to find all of them!
Attachment 592284
Attachment 592289
And now for my fuel filter. I reinstalled my line from the pump to carb. I have this filter inline now, but i don't think its meant to be the primary filter.
Attachment 592298
Attachment 592299
I also have this filter. The barb on the side I think goes to the fuel return line, but my question is, does this filter have to be after the pump, or can I put it in before the pump, which would be more convenient?
Attachment 592315
Please please please! ditch that glass filter, I have seen several vehicles burn to the ground because the glass breaks and covers the engine in fuel while it is running down the road.
Wix makes a clear plastic one that is a much better unit that is what I recommend and run on all my rigs.
I really like the switch/stereo panel you put together. That is going to be sharp and handy. Also a big fan of the orange.
"He used to be a pretty nice feller, now he's a welder"
AMC 304 V8, NV4500, Dana 300, Dana 44, 9 inch, M.O.R.E. SRS, YJ tub.
AT3 US Navy 1999-2003
Cum catapultae proscriptae erunt tum soli proscript catapultas habebunt
(When catapults are outlawed, only outlaws will have catapults)
MrBeast is offline
post #185 of 853 Old 03-30-2013, 06:18 PM Thread Starter
hasselback
Thanks, although I'm planning on ditching it to put the radio in the dash where it belongs. May cut it down though and keep it just for the switches. We'll see.
post #186 of 853 Old 04-01-2013, 05:33 PM Thread Starter
hasselback
Getting ready to paint the Jeep, but couldn't find the exact shade of orange I wanted, so I decided to mix my own. The pic on my phone is what I mixed, trying to match the Poison Spyder Jeep, which I think looks pretty awesome.
post #187 of 853 Old 04-02-2013, 12:03 AM
MrBeast
1980 CJ7
Great color. Orange is one of my favorites.
MrBeast is offline
post #188 of 853 Old 04-06-2013, 05:12 PM Thread Starter
hasselback
Did a little work on the audio today. Was trying to decide what to do with my 6x9's, and saw there was just enough room to recess them into the wheel wells behind the back seat. So I cut the holes out, and since the back of the speaker would be exposed, I got some baffles to put through the hole first. I siliconed the baffle to the tub under the carpet, then installed the speakers, and grills for a nice clean look. And they sound great!
1984 CJ7 I6 258 Bone stock
"Screw the brakes, just make the horn louder!"
My build thread
post #189 of 853 Old 04-15-2013, 04:53 PM Thread Starter
hasselback
Snuck out to the garage today after work and prepped and painted my grill. Its a little darker than I hoped, but I'm just going to have to live with it for now! Ill probably end up painting it again in a few years anyway...
My build thread
post #190 of 853 Old 04-15-2013, 04:57 PM
skizriz
1978 CJ7
I wondered how you were coming along. Haven't heard much lately. I like the color. There aren't many vehicles that can pull off orange.
A nice CJ is one of the few that can.
skizriz is offline
post #191 of 853 Old 04-15-2013, 04:58 PM Thread Starter
hasselback
Realizing now that my Phone takes horrible pictures!
post #192 of 853 Old 04-15-2013, 05:06 PM Thread Starter
hasselback
Thanks.
It's coming, slowly it seems. Spent almost 2 weeks trying to mix this darn paint. I'd order a couple quarts from Summit, mix it up, decide it needed some more yellow, so had to order another quart, then I wanted it metallic, so ordered some orange flake, then decided I needed some more red, so had to order yet another quart! I got enough paint to paint probably 3 Jeeps now! I finally had enough, so I'm going with it. I'm sure it will grow on me once I get the clear on. And I didn't do anything this past weekend with it do to fishing season.
post #193 of 853 Old 04-17-2013, 10:41 AM Thread Starter
hasselback
Getting extremely frustrated here! You can't really see it in the pic above, but the paint on my grill has a real bad orange peel effect going on. I know it should be laying flatter than this coming out of the gun. Right now, my spray gun is acting like it's a splatter gun! It's a Kobalt gravity geed gun from lowes, and I'm running about 45-50 PSI through it. I'm not sure if I need to thin the paint, turn up the pressure, or what, but I'm about ready to just roll on herculiner over the whole darn thing!
Any thoughts would be welcomed.
post #194 of 853 Old 04-17-2013, 12:30 PM
Davis77Cj
1977 CJ7
can you spray a piece of cardboard or something so we can see what is coming out of the tip?
Only in America do you have the God given right to be loudly opinionated about something that you are completly ignorant of.
Davis77Cj is offline
post #195 of 853 Old 04-17-2013, 12:54 PM Thread Starter
hasselback
Its coming out of the tip like splatter paint
My build thread
BUILD THREAD: Project "Ghetto Fabulous" motiv8ya Jeep CJ Forum 804 06-11-2017 03:57 PM
"Gaucho" CJ stepside pickup build jscherb Jeep CJ Forum 1449 11-15-2016 03:17 PM
Justins "Civillian Jeep" Build nacheswheelin Jeep CJ Forum 47 01-03-2013 09:36 PM
1985 "Special Edition" CJ7 Restoration Build Thread elliottferrell Jeep CJ Forum 38 07-23-2012 09:09 AM
1979 CJ7 "Spartan" Build Report Jmaas Jeep CJ Forum 20 01-09-2009 08:14 PM
