Has anyone installed the new Painless 10150 CJ harness? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Has anyone installed the new Painless 10150 CJ harness?
Spartan Locker's at all time LOW exclusive from ROCKRIDGE FS: Jeep Fog Light LED Bulbs! Several Brightness Options! Bds fox ipf 2.0 racing series shocks now available at rock
Unread 10-20-2014, 06:02 PM   #1
jetmech1
The Painless 10110 has supposedly been improved and now is the 10150. Looking for some input before I drop nearly $800 on it!
jetmech1 is offline   Reply With Quote Quick reply to this message
Unread 10-20-2014, 06:31 PM   #2
stephens_cj5
1981 CJ5
I installed the 10110 and was happy with it. If the 10150 is an improved version you couldn't go wrong. It should be worth the investment.
1981 CJ5 ground up restro in progress, finished product will have: 4.2 w/ a 4.0 head conversion, headers, Howell TBI, HEI, D300, AMC 20, D30, 3" lift w/ 33x12.50 BFG. All new hardware, all diffs rebuilt.
stephens_cj5 is offline   Reply With Quote Quick reply to this message
Unread 10-21-2014, 08:10 AM   #3
WindKnot
WindKnot's Avatar
1977 CJ7
Centech also makes a very nice harness for less money. I'm very happy with mine.
http://www.centechwire.com/Jeep-CJ-W...Harness-JP.htm
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration? http://www.jeepforum.com/forum/f8/ph...ation-1807257/
WindKnot is offline   Reply With Quote Quick reply to this message
Unread 10-21-2014, 09:05 AM   #4
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
I will second the Centech set, worked great on mine also. From the number of 'help me' posts with painless, it is anything but painless... Haven't seen anyone in trouble post for help with Centech.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is online now   Reply With Quote Quick reply to this message
Unread 10-21-2014, 10:16 AM   #5
pinaplebob
pinaplebob's Avatar
2011 WK
Cent each harness look interesting. Never heard of them before. Off to do research as the price doesn't seem too bad.
pinaplebob is offline   Reply With Quote Quick reply to this message
Unread 10-21-2014, 10:59 AM   #6
little79cj
little79cj's Avatar
1979 CJ5
I'll have to look and make sure but I installed a painless harness in my 79, and well contrary to popular belief if you follow the instructions it is pretty painless. Installed the complete harness in one weekend being sure to take my time and it started up right off the bat first time go. Albeit I hooked up my taillight wires backwards when I did mine but 15 min later problem solved. The drawback to the painless IMO is it is really expensive. Also everything works correctly in my jeep.....for now.
79 CJ5 - Sandy
87 Cherokee - Onion
99 Cherokee - Diamond
little79cj is offline   Reply With Quote Quick reply to this message
Unread 10-21-2014, 05:42 PM   #7
WindKnot
WindKnot's Avatar
1977 CJ7
Here's their fuse panel...
This is the firewall bulkhead. You can see the wires are clearly labeled...
You can see some of the connections behind the dash...
Excellent quality American work with American parts.
Unread 10-21-2014, 06:20 PM   #8
stephens_cj5
1981 CJ5
I like the way they did the dash vs Painless. The Painless kit was easy to install, the hardest part was the dash but this makes it easy.
Unread 11-03-2014, 07:40 PM   #9
Mortgage-payer
1976 CJ7
What makes the Painless worth 2x the Centech?
I call it a distributor, not a dizzy.
Mortgage-payer is offline   Reply With Quote Quick reply to this message
Unread 11-04-2014, 07:44 PM   #10
jetmech1
The Centech Jeep CJ specific wiring harness is more than the Painless harness according to my research. I'm only looking at pre-terminated factory style harnesses.
Unread 11-04-2014, 07:57 PM   #11
WindKnot
WindKnot's Avatar
1977 CJ7
Your research is faulty. Painless is about $625 vs $400 for the Centech.
Unread 11-04-2014, 07:59 PM   #12
jetmech1
where can I get a pre terminated Centech CJ harness for $400?
Unread 11-04-2014, 08:07 PM   #13
WindKnot
WindKnot's Avatar
1977 CJ7
From Centech themselves. http://www.centechwire.com/Jeep_c16.htm
Unread 11-04-2014, 08:12 PM   #14
jetmech1
Wonder why it shows a harness for up to 1983? What about 84-86?
Unread 11-04-2014, 08:17 PM   #15
WindKnot
WindKnot's Avatar
1977 CJ7
That's been already discussed. There is no computer harness and they don't want to mislead you. 1983 is the cutoff. Painless doesn't either, but they imply it. I'd encourage you to read the whole thread.
