Has anyone ever cracked an AMC 20 - JeepForum.com
post #1 of 9 Old 02-10-2010, 07:08 PM Thread Starter
Galt
Galt's Avatar
1983 CJ7
Has anyone ever actually cracked an AMC 20 housing or tubes? I'm looking to build a rear axle but don't know for certain yet if I want to rebuild the 20 or pick up a dana 44 instead. I don't currently or plan to do any severe wheeling so I assume I would not be throwing money away if I decided to put the money into the AMC.
A=A
1983 CJ7 304 V8
1985 CJ7 258 I6
1993 RX7 1.3L Rotary/ GT40R turbo/484 rwhp
2002 F-150 Lariat 5.4L V8
2007 GMC Yukon Denali 6.2L V8
Galt is offline
post #2 of 9 Old 02-10-2010, 07:21 PM
texasimport
1978 CJ5
my 2 cents. . . . .I would think a 20 behind a 6 cylinder that does not see a lot of off road abuse would last a while especially if you use one piece axles when you go through it.
78 304-CJ5
texasimport is offline
post #3 of 9 Old 02-10-2010, 07:33 PM Thread Starter
Galt
Galt's Avatar
1983 CJ7
Let me rephrase. I use my jeep alot off road for hunting and camping trips. I don't climb the sides of cliffs and what not though. That's what I call severe wheeling. I do get into some hairy spots from time to time. In other words it's not a strictly pavement jeep. It's just that I read so many people swapping out the AMC, IMO mostly due to the two piece axle I was just curious if anyone had actually had a housing failure with one.
A=A
1983 CJ7 304 V8
1985 CJ7 258 I6
Galt is offline
post #4 of 9 Old 02-10-2010, 07:40 PM
paveland
Most people who are hardcore climbing get rid of the AMC 20, but I have always heard that if you weld the axle tubes, truss it, and get one piece axles there are actually really tough.
paveland is offline
post #5 of 9 Old 02-10-2010, 07:43 PM
ReconRabbit
1983 CJ7
I have a mild v8 with an amc20,all stock even 2pc axles. I have put it through its paces and have yet to see any failure from it. I'm even running 33 inch tires.
If your Jeeps not leaking it's out of fluids.
ReconRabbit is offline
post #6 of 9 Old 02-10-2010, 07:44 PM
garbageman
1979 CJ7
x2 - Weld the tubes to pumpkin, 1 piece axles and keep the tires under 33" and you'll be fine. The internals are stronger then a 44. If you want 35" tires or more or want to due more extreme stuff, add a truss. The weak spot is the 2 piece axles and thin tube walls.
1979 CJ7 - Propane powered 258/TH400/Q-trac- 2015 Project
Sold:
1974 CJ5, 1980 Wagoner, 1976 CJ7
garbageman is offline
post #7 of 9 Old 02-10-2010, 07:47 PM Thread Starter
Galt
Galt's Avatar
1983 CJ7
Thanks for the replies!
A=A
1983 CJ7 304 V8
1985 CJ7 258 I6
Galt is offline
post #8 of 9 Old 02-10-2010, 07:53 PM
JeepHammer
Running On Empty...
1973 CJ5
I've never seen the housing split, but I've seen the welded steel tubes lay open down the seam before.
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #9 of 9 Old 02-10-2010, 08:13 PM
80cj
80cj's Avatar
1980 CJ5
How dd that happen?
80cj is online now
Help Cracked bellhousing rustymudder Jeep CJ Forum 6 08-22-2009 04:57 PM
CJ T18 with cracked case No_Bs Jeep CJ Forum 14 01-09-2007 04:48 AM
Cracked Flywheel? thebeast77 Jeep CJ Forum 7 06-24-2006 08:39 PM
cracked head aesir Jeep CJ Forum 1 05-03-2006 10:39 AM
Oil Pan Cracked!!! longlimb Jeep CJ Forum 9 07-06-2005 10:05 PM
