hardtop side glass installation - JeepForum.com
post #1 of 11 Old 11-17-2004, 07:51 AM Thread Starter
NJCJ7
NJCJ7's Avatar
okay, i managed to get the glass out of my old top, but can't get it in the new one. A friend of mine had used the weed wacker line trick on a windshield, and i think it might've worked for this too, but we couldn't even get it started.
How have you all done this? did you put the seal on the hardtop and the press the glass in? or do you put it on the glass first then press it in as one piece, glass and seal?
ANY ideas are appreciated...
1985 CJ7 MC2100,TFI, 2.5" BDS suspension, Full Cage, 31" Mud Tires, 1/2" MORE shackles, Aussie Locked AMC 20
NJCJ7 is offline
post #2 of 11 Old 11-17-2004, 09:33 AM
Geer_hed
Geer_hed's Avatar
I had to put the seal on the hardtop frame first, leaving one corner loose, and then work the glass in 1 .5 inch at a time. What a PITA.. I f'd the other side of the hardtop trying to repair it and eventually just went with lucite on both sides, which was SCREWED in .... doesn't look so great, but it's a backup top and it works. Good luck, it's a crappy job...
85 CJ7 / 258 / T176 / Dana 30/ AMC 20
Geer_hed is offline
post #3 of 11 Old 11-17-2004, 11:03 AM
jeepskate
I'm trying to do the same thing and think I'm just going to pay the local glass shop a few bucks to do it for me. I tried the line method, and it ended up butchering the seal, so now I have to buy a new seal.
jeepskate is offline
post #4 of 11 Old 11-19-2004, 09:40 AM Thread Starter
NJCJ7
NJCJ7's Avatar
got them in last nite:
put the seal on the hardtop, got the glass started and worked the gasket around with a wooden paint stirrer and (carefully) with a butter knife... bit of a PITA, but not too bad...
NJCJ7 is offline
post #5 of 11 Old 11-19-2004, 11:02 AM
jeepskate
Cool. I guess I'll give it another try this weekend before I throw in the towel.
post #6 of 11 Old 11-19-2004, 06:49 PM
jeepmor
jeepmor's Avatar
Red face rope, not weedwacker line
I put one of these "type" of windows in before and had the seal around the window, then put rope around the outside groove of the seal. My rope was about 1/4"-3/8" in diameter. I had my wife hold the window up tight and aligned to the opening from the inside, and I pulled the rope from the outside. Worked great and was incredibly easy considering I was pretty nervous about it.
I think the weedwacker line is too small a diameter and is cutting your seal or otherwise creating too much pressure. The larger diameter rope distributes this force over a larger area, reducing pressure, thus reducing the tearing to your seal. It was a two person job. You may want to spray some silicone spray or similar on your seal to ease it's fitting through the gap when pulling the rope.
jeepmor
jeepmor is offline
post #7 of 11 Old 11-20-2004, 03:28 PM
gunkysputter23
Yes, the weedwhacker line is too small of a diameter. Use 1/4 to 5/16 inch or so cotton rope. Dope it up good with dishwashing soap or gojo juice. Put the seal on the window and run the greased up rope around the outside of the seal in the groove. Have someone hold the window from the outside while helping to push the window into place. Have the ends of the rope on the inside where you'll be pulling the lip of the seal over the window frame. Begin at one end by sticking the bottom corner into the frame. with the ropes being pulled out slowly and the person on the other end of the window push some but not too much to rip the seal, pull the window into place.
Done this many times with VW side windows and winshields.
Remember, you can slightly bend the glass some to get it into place without breaking it. Be firm but not too rough.
gunkysputter23 is offline
post #8 of 11 Old 12-08-2004, 01:30 PM
jeepskate
Got mine in a couple of weekends ago. Started over again and put the seal in first and sprayed the heck out of it and the edge of the glass with silicone spray. A little careful prying with a small screwdriver, and it popped in.
post #9 of 11 Old 12-08-2004, 05:24 PM
gunkysputter23
I'd watch that screwdriver technique there. As a rule of thumb it's best to never pry on glass with any type of metal object, that is of course unless you like chipped and broken glass.
post #10 of 11 Old 12-08-2004, 09:44 PM
jeepskate
I kept the screwdriver off the glass as much as humanly possible (got a little tricky at the corners, so I just had to slow down & be extra careful). Basically I got the screwdriver down in the channel and ran it along which got the edge of the channel up against the outer edge of the glass. Once I had all of the rubber sitting like that other than what I was able to seat fully, I just had to carefully push in on the glass and it popped into place.
post #11 of 11 Old 12-10-2004, 11:02 AM
gunkysputter23
Excellent. As long as you've found a technique that works for you. I'm just sayin, be careful.
Hard top side glass installation ? yellow85cj Jeep CJ Forum 2 06-12-2009 10:48 PM
4WD glass body installation kit question OSUAV8R Jeep CJ Forum 1 03-27-2008 08:28 PM
Installing Hardtop Side Glass AbercrombieCJ7 Jeep CJ Forum 0 07-31-2003 06:01 PM
Glass tub installation advice? hfjeff Jeep CJ Forum 11 04-16-2003 07:31 AM
cj7 hardtop glass kcmudduck Jeep CJ Forum 0 10-31-2001 12:27 PM
