Hardtop on Fiberglass Windshield Frame? - JeepForum.com
post #1 of 7 Old 10-05-2007, 10:34 AM Thread Starter
TJTony
got my 85 cj7 a few months ago, and am planning on putting the hardtop on soon- my tj didn't have a hard top, so this is new to me- i thought it would be pretty simple, but i noticed where the top rests on the windshield, there are holes- however, the previous owner put a fiberglass windshield frame in. there are no holes in it. do i have to drill holes, or is the frame just no good for a hard top?
Thanks-
TJTony is offline
post #2 of 7 Old 10-05-2007, 12:55 PM
JoonHoss
2011 JK Wrangler
I believe that at a minimim, you want to reinforce the frame portion with metal strip, or some type of insert.
the front edge isn't completely structural, but you absolutley want it secured.
theey do make a repair kit of sorts, for the hard-top at least, perhaps you could reverse it, and use it on the windshield?
http://www.quadratec.com/products/13022_101.htm
HTH
Hoss
"Gimme three gallons of low lead; two hot dogs and a strawberry soda..."JGW
JoonHoss is online now
post #3 of 7 Old 10-05-2007, 02:17 PM Thread Starter
TJTony
Thanks Hoss- but I'm going to have to drill holes into the fiberglass?
TJTony is offline
post #4 of 7 Old 10-05-2007, 03:27 PM
JoonHoss
2011 JK Wrangler
depends, you may, or you may need to attach a metal strip and drill it, but you will need something
Hoss
post #5 of 7 Old 10-06-2007, 06:22 AM
BIGJMCCONNELL
1977 CJ7
Yes you need to drill. Put the top on, mark holes, remove top, then drill. Maybe you can drill with it on there, but I couldn't because of my roll cage.
Everything held up fine for about 4 yrs of on/off. Then the holes started stripping. I made a thin plate that sandwiches the windshield frame. I think you can buy these, but I made mine.
Good luck.
--John
1977 CJ-7 with Ford 302 engine
2.5 inch springs Matkins Frame with 1.5 inch body lift and all Fiberglass body D30/M20 w/3.54 gears, Moser 1-piece and Rear Aussie Locker, Jeep T-18w/Dana 20 and 35" tires Dual Flowmaster Exhaust, 6 point roll cage, OBA and a bunch of other stuff.
BIGJMCCONNELL is offline
post #6 of 7 Old 10-30-2007, 11:02 AM Thread Starter
TJTony
the 4wd catalog shows a fiberglass body that has the holes pre-drilled, with the "sleeves" (i don't know what else to call them) that the bolts would be threaded into. i'm wondering if i can drill a hole, insert the threaded sleeve (secure it somehow), and be all set. i'm probably better off just getting a steel windshield frame anyways!
TJTony is offline
post #7 of 7 Old 10-30-2007, 11:20 AM
John Strenk
John Strenk's Avatar
1976 CJ5
They are probably nutzerts. IF installed correctly they work great. Don't know the thickness of the windshield but that will have to be determined before selecting the proper fastener.
John Strenk is offline
Metal strip - Hardtop to Windshield frame TomCombo Jeep CJ Forum 6 03-02-2009 08:15 AM
Help with hardtop and windshield frame Rocketansky Jeep CJ Forum 2 12-08-2008 06:32 PM
Fiberglass Windshield Frame issues chet44 Jeep CJ Forum 15 12-02-2008 07:56 PM
Fiberglass Windshield pf1130 Jeep CJ Forum 10 05-27-2005 04:43 AM
Fiberglass Windshield Marco Jeep CJ Forum 12 08-06-2003 09:14 AM
