Hardtop Dome Light Wiring - JeepForum.com
post #1 of 8 Old 02-05-2010, 08:45 AM Thread Starter
TexasCJ7
I have found a CJ hardtop but haven't looked at it yet. The seller said that it has the dome light but no wiring. Can someone either post a pic or describe how the dome light is wired?
Thanks in advance,
83 CJ-8
86 CJ-7
TexasCJ7 is offline
post #2 of 8 Old 02-05-2010, 09:04 AM
wm69
Just a plug. If you look in the back drivers corner of your Jeep, the plug should be there. It works off of your headlight switch; you turn the knob to the left and it turns on your underdash/ courtesy lights and the hardtop light.
wm69 is offline
post #3 of 8 Old 02-05-2010, 10:45 AM
crcj7
Thanks in advance,
i have the plug a lot of them get broken its alot eaiser to just get one or 2 of those led tap lights they sell at the hardware store they come with velcro and are a lot brighter then stock
geter done goter did flipeder over didit agian
i need an nv3550 any one need a hardtop
crcj7 is offline
post #4 of 8 Old 02-05-2010, 03:40 PM
CJunk
If your cj never had a hard top on it, that harness will not be pluged in. Follow the wires from the back to the front near the e-brake pedal, if its plugged in you're ready to go if not, locate the other end and plug it in.
If the jeep came with a factory soft top they left them unplugged.
CJunk is offline
post #5 of 8 Old 02-05-2010, 07:15 PM Thread Starter
TexasCJ7
Thanks, unfortunately I don't have the wiring, but I don't think it will be to tough to wire it into the interior light switch.
83 CJ-8
86 CJ-7
TexasCJ7 is offline
post #6 of 8 Old 02-07-2010, 01:18 PM
wm69
My 85 was a factory soft top and it had the plug....I thought they all had them.
wm69 is offline
post #7 of 8 Old 02-08-2010, 05:55 AM
Mike Romain
What flavor of CJ do you have then? All the ones I have looked at had the extra orange and black wires running to the back tub corner inside the harness. You might have to pull open the harness to find them.
Mike
Mike Romain is offline
post #8 of 8 Old 02-08-2010, 03:33 PM Thread Starter
TexasCJ7
Thanks Mike, I will look inside the harness.
83 CJ-8
86 CJ-7
TexasCJ7 is offline
Aftermarket Dome Light? Mike1084 Jeep CJ Forum 16 08-10-2014 02:58 PM
Hardtop dome light??? awful8484 Jeep CJ Forum 8 11-01-2009 05:10 PM
Hardtop Dome Light - Found a direct replacement Houdini Jeep CJ Forum 8 02-09-2009 09:52 PM
hard top dome light GO-NOLES84 Jeep CJ Forum 5 10-20-2008 12:44 PM
Dome light okjeep98 Jeep CJ Forum 6 01-02-2007 07:46 PM
