I have found a CJ hardtop but haven't looked at it yet. The seller said that it has the dome light but no wiring. Can someone either post a pic or describe how the dome light is wired?
Just a plug. If you look in the back drivers corner of your Jeep, the plug should be there. It works off of your headlight switch; you turn the knob to the left and it turns on your underdash/ courtesy lights and the hardtop light.
i have the plug a lot of them get broken its alot eaiser to just get one or 2 of those led tap lights they sell at the hardware store they come with velcro and are a lot brighter then stock
If your cj never had a hard top on it, that harness will not be pluged in. Follow the wires from the back to the front near the e-brake pedal, if its plugged in you're ready to go if not, locate the other end and plug it in.
If the jeep came with a factory soft top they left them unplugged.
What flavor of CJ do you have then? All the ones I have looked at had the extra orange and black wires running to the back tub corner inside the harness. You might have to pull open the harness to find them.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
