Hard top window seal installation - JeepForum.com
post #1 of 30 Old 03-25-2010, 09:00 AM Thread Starter
Sherms-CJ7
1982 CJ7
I have an old hard top, but the side windows are out. I bought new seals for the top, but I haven't been able to tell which way the seals get installed. How do you tell which side of the seal should be installed to the inside of the Jeep? It just seems like it could sort of go either way, but only 1 way is right.
Sherms-CJ7 is offline
post #2 of 30 Old 03-25-2010, 10:09 AM
Green091
1983 CJ7
If you posted a pic of them I could tell you. I have never changed the glass on a jeep hardtop, but I own a glass shop and could tell you which way it goes. I am assuming they are gasket glaze, if so the locking strip goes to the outside.
Green091 is offline
post #3 of 30 Old 03-25-2010, 10:44 AM Thread Starter
Sherms-CJ7
1982 CJ7
Cool Thanks for replying ... pics to follow ...
post #4 of 30 Old 03-25-2010, 10:57 AM Thread Starter
Sherms-CJ7
1982 CJ7
Ok, here's one of the seals ...
post #5 of 30 Old 03-25-2010, 11:45 AM
jeepsarecool
jeepsarecool's Avatar
1982 CJ7
That's for the side window???? I'm confused.
Check out my
CJ7 - God's gift to the masochist.
jeepsarecool is offline
post #6 of 30 Old 03-25-2010, 12:08 PM
CJ Chet
I have the same seals, and the same question!
'86 CJ7
'04 AEV RUBICON
2015 Grand Cherokee Limited
CJ Chet is offline
post #7 of 30 Old 03-25-2010, 12:20 PM
Green091
1983 CJ7
The smooth side goes in. The narrow slit goes around the body and the wider one goes around the glass.
The first step is to run the gasket on the body without the glass in it. Then spray glass cleaner in the glass channel of the gasket to lube it up. EDIT - When you run the gasket on the body put the seam where the two ends meet up on the bottom in the middle.
Then set the bottom of the glass in the bottom channel of the gasket. Glass shops have what they call a "bone tool" (some places may call it a windshield stick) which is basically a piece of 1/4" thick hard plastic about 6 inches long and a 1/2" wide with rounded ends that they use to work the gasket around the edge of the glass. You should be able to get a couple from your local glass shop for a few bucks or so. You can use something metal, but I wouldn't advise it since you don't have a feel for how hard you can pry without breaking the glass.
Use the bone tool to work the glass into the gasket. Start on the bottom corners and work your way up. If one side gets tight try working the other side. If both are tight try slapping the glass to the left or right and get it to slide all the way to one side so you can work on the other. You can get a friend on the inside to push out on the gasket with one bone tool while you work on it from the outside with the other. Be careful not to tear the gasket.
Once the glass is completely in the gasket you need to "lock" it in. In the bottom picture you posted the left side of the gasket is the locking strip. You need the longer leg on the bottom to lip under the shorter upper leg. Spray the gasket with glass cleaner again and use the bone tool to lift open the upper leg while at the same time pressing the longer leg behind it. They make a tool specifically for this, but it isn't necessary . Work it all the way around and once it is fully locked into place you are good to go. The glass is completely secure and water tight without any type of sealants.
I hope I explained everything clearly enough for you to understand. Feel free to ask any other questions. This is one of the easiest and simplest ways to install glass once you get the hang of it. If it gets overwhelming a glass shop shouldn't charge too much to install it for you and they should be able to do it fairly quickly.
Green091 is offline
post #8 of 30 Old 03-25-2010, 12:22 PM
jeepsarecool
1982 CJ7
I was thinking mine were a loop-type seal with no ends. Maybe I'm wrong. Looking at your photo though, I would think the side without the groove or lip sticking out would go to the outside.
Check out my
post #9 of 30 Old 03-25-2010, 08:38 PM Thread Starter
Sherms-CJ7
1982 CJ7
Great directions! Sadly, I do have a question - sorry! My confusion arises from the fact that there are 3 ... slits, and I'm not sure of what you meant by the "smooth side"? Looking at the top-right picture, I was thinking that you mean the top of the seal. Then, the big slit for the window is on the left and the narrow slit for the body is on the right. But, what about the oddly shaped slit on the bottom (again, 1st row, 2nd picture).
Thanks again - this has confused me for ... ah, well, a real long time.
post #10 of 30 Old 03-25-2010, 08:57 PM
Skerr
2nd picture...
The narrow, longer slit on the right pushes onto the edge of the opening.
The wider, shorter slit on the left is the glass channel.
The odd-shaped slit is the lock, and it goes on the inside.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #11 of 30 Old 03-25-2010, 09:06 PM Thread Starter
Sherms-CJ7
1982 CJ7
Thank You Much - Great info! Now all I have to do is to "get 'er done!" Then again, maybe I should paint it first!?
post #12 of 30 Old 03-25-2010, 09:10 PM
Skerr
I think you would get "convenience points" if you painted it without the glass.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #13 of 30 Old 03-25-2010, 09:11 PM
Skerr
Awesome avatar BTW!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #14 of 30 Old 03-25-2010, 09:28 PM Thread Starter
Sherms-CJ7
1982 CJ7
Thanks! I was in the Navy and flew in those old planes. I was stationed in Jacksonville, FL and, in fact, that's where I bought my CJ - that was back in 1994 ... feeling pretty old these days
post #15 of 30 Old 03-26-2010, 05:01 AM
mmerlina
Image Glassworks, Inc.
mmerlina's Avatar
I know you already got your answer but you aren't the first to ask and probably won't be the last.. so I went ahead and labeled your photo, hope you don't mind..
Please also note that the interlock goes on the outside of the vehicle.
Similar rubber is used on many construction vehicles like backhoes and stuff.. and you simply wouldn't be able to get to the rubber from the inside.. it would be tucked away in a corner somewhere. Also many school buses use this rubber for their back window.. next time you walk by one look up.
Mike
1986 Jeep CJ7 (
Remanufactured 258, ARB lockers front & rear, 4.10 Yukon gears, 35x12.5" Super Swamper SSR's, Motorcraft 2100, 4.5" Rubicon Express Extreme-Duty lift, York 210 OBA, Big Daddy steering, Tatton rear CV driveshaft, Herculined interior, TJ flares, lots of body & upholstery work
mmerlina is offline
Door Seal Installation (How To) MPD280 Jeep CJ Forum 3 05-19-2009 10:20 AM
4wd outer window door seal ? a2tripp Jeep CJ Forum 0 11-18-2008 09:04 PM
Help Please - AMC 20 housing seal installation wheelinjames Jeep CJ Forum 12 03-06-2007 06:10 PM
CJ-7 Windshield/Cowling Rubber Seal Installation....Tips? RaleighDodger Jeep CJ Forum 1 10-29-2005 07:20 PM
