Pop it completely out and clean the tops window edge and inside the rubber groove itself with a Q-tip (WD-40). Reset the rubber gasket via its groove so it's loosely set and give it a steady gentle EVEN push. The glass should pop right on in. You will feel it when it sets good. It's not that hard. Just remember; even pressure on glass. Sometimes they will pop out if you flex the top. Good luck!
Thanks. I tired this got confused a little. Put the gasket on the window first and then try to push both into the top at the same time? Or put the gasket on the top and push the glass into the gasket?
Take the glass and gasket out completely.
Clean all edges and gasket.Lube the gasket with silicone or liquid soap.
Install gasket on glass.
Grab twine ot thick string and wrap around the window.
This works the easiest if you have both ends of the string together at the bottom center of the glass.
Put bottom of the the glass in the opening.
Once you have it set in place have someone push the glass while you pull the rope.
What you are doing is lifting the edge of the gasket away from the fiberglass then exerting force to push the gasket back into position.
I am sure U Tube might have a video on how to install auto glass.
Thanks. I was searching you tube for installing a cj hard top window a didn't find much. I will search looking for the string method. Thanks for your help.
Haven't tried again yet. I had some time last night but decided to clean the soft top I have on it now and take it off. Also built a place to store it in the rafters.
Tried again tonight. Didn't have a helper so I just tried to use a flat balde screw driver to fold out the gasket. Wasn't having any luck it just seemed like it wanted to bind.
I will wait until I can have someone help me push from the outside. I found this you tube video using the method GMA mentioned I think I will try this next.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
