Hard top side glass installation ? - JeepForum.com
post #1 of 3 Old 06-12-2009, 02:26 PM Thread Starter
yellow85cj
Picked up a hard top this week. In good shape except one side glass is out.
Question is, does the gasket go on the glass, then install into the top as a unit, or install the gasket on the top then install the glass?
Currently in pieces - all of them
yellow85cj is offline
post #2 of 3 Old 06-12-2009, 06:04 PM
mmerlina
Image Glassworks, Inc.
mmerlina's Avatar
The rubber I have on my hardtop is the type that goes onto the frame first and then you use a fiber stick and silicone spray helps too, to just feed it in. Start with the bottom first so it won't drop down. We use a straight screwdriver at the shop to do this.. but if you don't do it everyday.. it's easy to break it that way too.. try a fiber stick.
Mike
1986 Jeep CJ7 (
Remanufactured 258, ARB lockers front & rear, 4.10 Yukon gears, 35x12.5" Super Swamper SSR's, Motorcraft 2100, 4.5" Rubicon Express Extreme-Duty lift, York 210 OBA, Big Daddy steering, Tatton rear CV driveshaft, Herculined interior, TJ flares, lots of body & upholstery work
mmerlina is offline
post #3 of 3 Old 06-12-2009, 10:48 PM
jp360cj
1977 CJ7
My hardtop was the opposite. The seal went on the glass first. Then a piece of rope went around the seal (where the hardtop goes). Put the window in from the inside and used the rope to pull the seal around the hardtop. I had a friend's brother who works at a glass shop help me out and he had some tricks to make it easier, but I can't remember what they were.
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline
hard top side glass seals? muddy93 Jeep CJ Forum 4 10-15-2009 04:45 AM
Hard top Side glass install sandtoy Jeep CJ Forum 3 03-22-2009 08:23 AM
4WD glass body installation kit question OSUAV8R Jeep CJ Forum 1 03-27-2008 08:28 PM
hardtop side glass installation NJCJ7 Jeep CJ Forum 10 12-10-2004 11:02 AM
Glass tub installation advice? hfjeff Jeep CJ Forum 11 04-16-2003 07:31 AM
