Hard starts. - JeepForum.com
post #1 of 9 Old 03-05-2013, 08:36 AM Thread Starter
jason400
Hard starts.
Ok I can't figure this one out and need a little help. I have a 85 CJ7 with a 258. The jeep has only 51K on it and is mostly stock. I recently put a new Weber 32/36 carb on it and a new fuel filter and pressure regulator (set at 4.5psi). I also replaced all of the vacuum lines. Here is the problem. Sometimes it fires right up, no problems, hesitation or anything. Other times it cranks over for 10-15 seconds before it fires. Either way when it's started it runs great, no misses, idles like dream, no stalling on take off etc. I think I am going to start with a new fuel pump (Carter P4070 with no regulator), any other ideas?
Thanks
Jason
jason400 is offline
post #2 of 9 Old 03-05-2013, 09:41 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Is your choke working?
Matt
Matt1981CJ7 is online now
post #3 of 9 Old 03-05-2013, 10:49 AM
wellmax
be sure fuel filter is orientated properly,
i have a weber on my jeep and i do not have a fuel pressure reg, the normal fuel pump provide the proper fuel pressure,
so far so good,
wellmax is offline
post #4 of 9 Old 03-05-2013, 10:59 AM Thread Starter
jason400
What is the proper orientation for a fuel filter? I noticed it sometimes doesn't have much fuel in it (glass filter).
jason400 is offline
post #5 of 9 Old 03-05-2013, 11:49 AM Thread Starter
jason400
I guess what I mean is there a proper orientation other then flow direction. Flow direction is correct and the filter is currently at a 24 degree angle, not sure if that makes difference.
jason400 is offline
post #6 of 9 Old 03-05-2013, 12:10 PM
86cj74.2L
86cj74.2L's Avatar
The glass filter is not the OEM fuel filter they are referring to.
86cj74.2L is online now
post #7 of 9 Old 03-05-2013, 12:37 PM
wellmax
the fuel filter on my old jeep is a metal type filter,
it has one inlet in and two outlets out:
the outside outlet is to be positioned at 12:00 high, the center outlet is for fuel to the carb.
the outside outlet is to let gas vapor return to tank,
if the outside outlet is positioned other than at 12:00 high, after the vehicle sets for a long period of time, fuel can be syphoned out of the carb and sent back to fuel tank.
when you next try to start the vehicle, you will have to pump fuel back into the carb, this may take a bit of cranking on the starter to get the vehicle running.
however, after short periods of non run time, the vehicle will start right up as fuel has not had time to syphon out of carb back to the tank.
this may not be your problem, but you need to insure you have the fuel filter properly onientated.
if it does not fix your problem, (cold engine) set carb choke with one push of fuel pedal, then check carb to be sure the choke closed, if the butterfly did not close properly, this can make the vehicle hard to start. If choke is working properly, you might try a full tuneup and timing set.
driving these new vehicles with fuel injection that always start right up,
have made us tend to forget the good old days of carbs and choke settings.
wellmax is offline
post #8 of 9 Old 03-06-2013, 09:55 AM Thread Starter
jason400
Since im using a weber carb I don't need that type of fuel filter. The gas tank return is from the carbon canister and the carb has a line running from it to the canister. I really think that fuel is slowly draining (gravity) back down the line through the pump over ectended time periods and that it takes a few cranks to re-pressurize the line to the carb. According to weber they recommend the carter rotary high volume low pressure fuel pump for optimal performance.
jason400 is offline
post #9 of 9 Old 03-06-2013, 10:01 AM
Matt1981CJ7
1981 CJ7
The fuel filter should sit at least as high in the engine compartment as the carb's fuel inlet. It should also sit level horizontally.
This will prevent fuel from draining from the system, and the long cold starts should go away. Here's what my 258/Weber 32/36/regulator setup looked like.
Hope this helps,
Matt
hard start , start problems
