hard starting first start of the day - JeepForum.com
post #1 of 7 Old 09-11-2012, 06:10 PM Thread Starter
fangool
Right now my cj7 has to crank for a considerable period of time before it will turn over. after it has been running and shut down it will start right up the second time no problem. this all started out with a broken ignition switch. in troubleshooting the ign switch problem i installed a new starter solenoid, hooked the coil and the switch leads backwards and made all kinds of trouble for myself in my haste, including arcing a hole with my wrench on the fuel pump and smoking the battery. i have checked the fuel situation by ensuring the fuel bowl was full manually, no fix. i noticed now that the coil wire on the solenoid is only reading 10 vdc. could that be my problem? something else? sorry if i'm rambling and thanks for any help.
fangool is offline
post #2 of 7 Old 09-12-2012, 12:26 AM
BagusJeep
1981 CJ7
Could be a number of things. Your profile does not mention any ignition or fuel mods so I assume you have a computer controlled Duraspark and BBD carb?
First off test the ignition. Do not bother with a voltmeter, get a 12V test bulb and two long leads. Connect one end to batt -ve and the other end to the red with tracer wire that goes to the coil +ve. In Run it should light up and be dim, and in Start it should be bright. I suspect you have an issue there.
Next look at the Duraspark module. There is a 2 pin plug. Unplug it an dlook for the white wire. In Start only the test bulb will be bright if connected here. It is a signal to the module that you are in Start and it will retard ignition about 11 degrees.
Lastly it may be your choke adjustment. Root aroud on here for Jeephammer's choke set up posts and follow them. When correctly set the carb should start you right up.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #3 of 7 Old 09-12-2012, 01:07 AM
SavSilvrCJ
Ensure your fuel filter is is level with the return line in the 12 o' clock position. If not it will cause fuel to leak out of the bowl. Also if it is a mech. fuel pump there is a check valve in those that like to go bad.
WFO baby!!!!!
SavSilvrCJ is offline
post #4 of 7 Old 09-12-2012, 02:52 AM
BagusJeep
1981 CJ7
PS the coil wire on the solenoid, the I tab, should show battery voltage in Start as it is fed from the solenoid and in Run should just show the voltage at the coil. In Run it is fed from the ignition switch via the ignition and ballast resistor, about 6.5-7V if all connected properly.
post #5 of 7 Old 09-12-2012, 06:26 AM
1FuddyMucker
1983 CJ7
Does your carb have electric choke?
If so you need to see if its working at the cold start up.
Don't breed em' if you can't feed em'.
1FuddyMucker is offline
post #6 of 7 Old 09-12-2012, 09:26 AM Thread Starter
fangool
i have a weber carb electric choke and as far as i can tell everything else is stock. the choke plates close and open as advertised. also, to rectify my start switch problem, i jumped the wires out of the column switch to a toggle switch and use the accesory circuit power to energize the start circuit. from the blue wire back it should be factory but i start with the key in the run position.
fangool is offline
post #7 of 7 Old 08-20-2013, 07:50 PM Thread Starter
fangool
for the sake of the forum, i finally found the starter was drawing more than twice the amperage that it should,(500+ amps). r&r starter, all works great. i also installed a painless duraspark 2 wire harness to fix the no start problem. i had a plethora of problems related to the ignition system. it feels good to be back off road again after almost a year of wrestling this stuff. thanks everyone!
fangool is offline
Need help with hard starting CJ-5 AJ075 Jeep CJ Forum 0 06-15-2011 05:41 PM
Good Start/Hard Start/No Start tigercreek Jeep CJ Forum 2 05-25-2010 07:48 AM
Hard starting CJ7 dhood Jeep CJ Forum 6 11-08-2007 08:48 AM
Very hard starting CJ7 258 leisyg Jeep CJ Forum 10 12-29-2005 07:52 AM
Hard starting medunwoody Jeep CJ Forum 2 12-04-2005 10:06 AM
