Hard starting - JeepForum.com
post #1 of 3 Old 12-03-2005, 10:57 PM Thread Starter
medunwoody
Hard starting
I've got a CJ7 with a 1978 258 6 cyl engine that the only way I can get it started is to rotate the distributor clockwise about 20 degrees. As soon as it fires I have to rotate it back to about the right position. This motor had a previous owner who didn't exactly have a clue what he was doing with the wiring so right now I just have it hotwired. Does anyone know how to hook up the two boxes (one about 4x4x2" and the other about 4x2x2") that have a bunch of wires coming out of them? Could this have an effect on the hard starting and the need to rotate the distributor to get it started? Right now I just have a hot wire coming off the battery and going to the coil, bypassing these boxes all the way.
Thanks
1985 CJ-7 with 4bt Cummins Turbo Diesel, nv4500, dana 300, 4.56 gears in stock axle housings just waiting to blow up with the extra power!
Columbia, MO
medunwoody is offline
post #2 of 3 Old 12-04-2005, 07:00 AM
cjjeeper258
Sounds like those boxes you describe are your timing/advance for the distributer. If I remembver correctly, I had one on my fender that controlled the spark advance or something to that effect. I never got a chance to mess with it since the original owner included an HEI setup with the Jeep and I installed it a week after I bought it.
Depending on how hacked the wiring is, you may want to just do the HEI upgrade and save some time.
cjjeeper258 is offline
post #3 of 3 Old 12-04-2005, 10:06 AM
gosupes
I agree with the HEI route, save some time and headaches. One thing I can think of, there was a wire coming off the starter solenoid that retards the spark during the crank cycle to help it fire. I think it was light blue but might be wrong. Maybe someone else knows what wire I am talking about.
It's just a Jeep, and if you don't wheel it once in a while, it's not even that.
gosupes is offline
Hard starting Problem....need help scanos Jeep CJ Forum 0 03-01-2009 06:05 PM
4.2L hard starting Jeepguy91 Jeep CJ Forum 4 12-01-2008 08:34 AM
Hard starting CJ7 dhood Jeep CJ Forum 6 11-08-2007 08:48 AM
Hard starting question Prospect62 Jeep CJ Forum 2 04-05-2006 01:22 PM
Very hard starting CJ7 258 leisyg Jeep CJ Forum 10 12-29-2005 07:52 AM
