Hard getting it into 4wd - JeepForum.com
post #1 of 3 Old 08-18-2003, 06:49 PM Thread Starter
DustinsCJ7
DustinsCJ7's Avatar
I seem to have a hard time putting my 84 Cj7 into 4hi or 4low. I put the trans in neutral and push in the clutch, go to shift the transfercase into 4wd and it wont go into either 4wd mode. I try to kinda "ram" it into 4wd and it still wont go into it. Only if im moving at about 5 or 10 mph will it "pop" into 4wd. The fluid is full as well.
Is there something im doing wrong? Anybody else have this problem?
Thanks,
Dustin
P.O.S Jeep club member #2
84 CJ7 nuttered up, TFI'ed, MC2100 conversion, 2" spring lift, 31" BFG MT's
79 LUV 4x4
Live like there's no tomorrow
DustinsCJ7 is offline
post #2 of 3 Old 08-18-2003, 07:21 PM
we4jeepn
When I am trying to shift into 4wd I come to a complete stop, I leave it in gear and push in the clutch, then as I am applying pressure to the xcase lever I gently let the clutch out a little. The xcase lever will fall into gear.
we4jeepn is offline
post #3 of 3 Old 08-18-2003, 08:21 PM
wm69
Do what webjeepin said and if it won't ease in, as you let the clutch out and the jeeps gets a rollin' a little, push the clutch back in and try popping it into gear then. My dad actually has to get rolling backwards a little to get his into gear (course his scrambler has about 3500 miles on it since new).... Both my CJ7's go into gear fine when rolling forward a little, but are hard as hell when at a stop.
wm69 is offline
Brake Pedal Hard, But Very hard to stop christiansteele Jeep CJ Forum 30 02-20-2009 09:13 PM
hard top/hard door paint scheme 82Renegade Jeep CJ Forum 7 10-03-2008 06:28 AM
Hard hard ride tiorocky Jeep CJ Forum 7 02-20-2008 12:03 AM
Hard Top/Hard Door compatibilities jatepper Jeep CJ Forum 4 06-30-2007 04:48 PM
Cj5 Hard Top And Hard Doors? ErikJordan Jeep CJ Forum 10 01-03-2003 02:49 PM
