hard doors - JeepForum.com
post #1 of 9 Old 11-17-2011, 12:10 PM Thread Starter
walt3006
hard doors
does anyone have or know where i can get a schematic of hard door to reassemble? 84 cj-7 but door is 79 i think. thx
walt3006 is offline
post #2 of 9 Old 11-17-2011, 12:19 PM
Renegade82
1982 CJ7
You do know the doors are different right? they will fit but the latching system is different, which effects the shell too.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #3 of 9 Old 11-17-2011, 12:24 PM
jmmorgan82
2009 JK Wrangler
If you do have the 79 doors, reassembly is easy as there are no linkages or rods to deal with. Do your doors have the paddle-type handle (later CJ's) or the lever-type (earlier doors). If it is for the earlier doors, I have the same ones on my YJ and could probably help you out.
jmmorgan82 is offline
post #4 of 9 Old 11-17-2011, 01:08 PM
Stumpbumper
I also have early style doors. I have a 84 hard top with 70's era doors on my 84 CJ7.
What are you looking for exactly?
1984 CJ7, 258..HEI..MC2100, T176/D300, D30/M20 lockers, lift, warn winch!
"When in doubt! Gas it out!"
Stumpbumper is offline
post #5 of 9 Old 11-17-2011, 01:29 PM Thread Starter
walt3006
thanks. have the old mounting system. looking for window assembly diagram to see what i'm missing.
walt3006 is offline
post #6 of 9 Old 11-17-2011, 01:30 PM Thread Starter
walt3006
have early handles. need window mount diagram so i can see if i have all the parts.
walt3006 is offline
post #7 of 9 Old 11-17-2011, 01:36 PM
Renegade82
1982 CJ7
There should be a diagram in the fsm. If I get a chance tonight I'll lay out the pieces and snap a pic. I just took one apart. I'm having the hoops taken out of two older lever style doors and having them put in my paddle style doors.
post #8 of 9 Old 11-17-2011, 02:39 PM
jmmorgan82
2009 JK Wrangler
Do you mean how the window crank/regulator fit inside the door, or how the actual window seals and what not go on?
post #9 of 9 Old 11-17-2011, 08:43 PM Thread Starter
walt3006
window riser assembly. missing part on bottom of window
walt3006 is offline
CJ5 hard top and full hard doors...thoughts? nightsource Jeep CJ Forum 7 08-16-2011 10:38 AM
yj hard half doors w/hard top? JUNK726 Jeep CJ Forum 11 07-05-2011 06:52 AM
ny one looking for some hard doors? bjf498 Jeep CJ Forum 0 05-11-2008 11:45 AM
Cj-7 doors revisited-hard doors the answer? newjeepowner Jeep CJ Forum 2 11-12-2007 07:27 AM
Two Piece Soft Doors VS. Lower hard doors with soft upper halves JeepScrambler Jeep CJ Forum 6 10-27-2005 06:29 AM
