Harbor Freight 5,000 lb Tow Bar $60!?! - JeepForum.com
post #1 of 16 Old 06-09-2013, 06:32 PM Thread Starter
smitty010203
1981 CJ5
Not sure if you guys know anything about these or not but I just picked one up for about 60 bucks with my 20% off coupon and I'm pretty excited about it. Seems like an incredible deal compared to other methods of moving ole Cjs farther distances. Just wanted to let everyone in on this. Wish I knew about it earlier.
Also they just had a 12,000lb winch for 300....... Now I know its Harbor Freight and its mostly china crap. But go on the website, pick an item, and read reviews, that's the trick to finding the deals. Check the reviews on both the winch and the tow bar
http://www.harborfreight.com/5000-lb...bar-94696.html
smitty010203 is offline
post #2 of 16 Old 06-09-2013, 06:42 PM
hotrod351
1955 M-38
yeah well what can you expect for $60.00. i wouldnt tow my jeep with it, i have way to much invested in my old willys. and that tow bar is designed to be used under perfect conditions, turn to sharp and its bends. cheap junk. come on, it weighs all of 29 pounds. i believe my tow bar weighs about 50 or 60 pounds.
hotrod351 is offline
post #3 of 16 Old 06-09-2013, 11:52 PM
pcoplin
I've used it. Works fine.
FullStack MotorSports
pcoplin is offline
post #4 of 16 Old 06-10-2013, 05:11 AM Thread Starter
smitty010203
1981 CJ5
Like I said, check out the reviews for it. seems to work great for everyone else. If I can take my jeep to the lake with me for 60 bucks Ill do it. My oem front bumper already has the holes to fit the brackets. I don't really think they would be selling them if peoples cars were breaking off left and right.
post #5 of 16 Old 06-10-2013, 05:25 AM
Oily
I would not trust the front bumper. Bad idea, .
Oily is offline
post #6 of 16 Old 06-10-2013, 06:58 AM Thread Starter
smitty010203
1981 CJ5
Definitely open to advice as I have never used a tow bar. What would you do Oily? Take the bumper off and hook it to the frame where the bumper connects?
post #7 of 16 Old 06-10-2013, 07:21 AM
waterdowg
Agreed not sure I would trust the front bumper for regular use. Now I did tow mine home about 50 miles. The tow bar was already on the Jeep, when I purchased it. But what I'm thinking of doing is mount 1/4" angle bolted to the frame and then the tow bar can mount thru the Bumper and the 1/4" angle.
waterdowg is offline
post #8 of 16 Old 06-10-2013, 08:07 AM
Oily
Gosh, I have a Blue Ox which I have not set up yet. I got it used for $30.00 used and it is a fold to store, on the tow vehicle type. It pivots over and rests against the bumper. New it costs http://tweetys.com/acclaimtowbar.aspx]about $430.00[/url]
The Blue Ox tow bars are designed to be attached to a base plate, which are engineered to mount to the individual frame of a particular vehicle.
I have an 85 Laredo with an excellent factory appearance and wish to keep it. I am trying to come up with a winch mount which also attaches to the frame and hope to be able to incorporate attachment points for my tow bar. (I also want a receiver hitch.)
You might try top end tow bar manufacturers for a base plate. I think they peek out from under the bumper. But, if you want a aftermarket bumper, many are stout enough for a tow bar.
Oily is offline
post #9 of 16 Old 06-10-2013, 09:07 AM
Oily
Look at the manufacturer's claim ... :
This adjustable tow bar is a great way to move cars from the road to your garage simply, safely and easily!
Oily is offline
post #10 of 16 Old 06-11-2013, 12:07 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Safety chains are highly recommended too.
I have a metal 2x4 bumper like what Eddie sells and had a couple brackets fabbed to connect the tow bar to the D-ring tabs. Have yet to use it, it is just my back-up plan to get it home if it ever breaks down...
Rick
Cutlass327 is offline
post #11 of 16 Old 06-11-2013, 05:29 PM
my_304_cj7
1976 CJ7
Don't let anyone dishearten you about the tow bar. It works great. I have had mine about a year now and put around a thousand miles on it. Always make sure the bolts are tight, mine did loosen up a couple of times so I always carry a ratchet and check on it when I stop and of course always use safety chains.
If you are turning hard enough to bend it, you should not be towing anything and I would question your common sense. I did use it on a holiday weekend in stop and go traffic and had to get on the brakes pretty hard and it came out unscathed.
'76 CJ7 Quadra-Trac 304 2.5" superlift 1" body lift 33" DuraTrac's
2014 Grand Cherokee Altitude
my_304_cj7 is offline
post #12 of 16 Old 06-12-2013, 11:14 AM Thread Starter
smitty010203
1981 CJ5
Glad to see there is someone out there on the forum has had good experience with it.
post #13 of 16 Old 06-12-2013, 04:06 PM
danielbuck
1946 CJ2
That tow bar is how I got my willys home I wouldn't hesitate to use it again.
danielbuck is offline
post #14 of 16 Old 06-12-2013, 05:25 PM
Artiemac
1979 CJ5
Well, I didn't get the HF tow bar, instead I went with Reese tow bar from walmart for $100. So I would assume the quality of both are about the same. I towed my jeep a little over 400 miles and as long as you hook everything up right and use common sense, you should be fine. If your front bumper is in good shape and the bolts that attach it to the frame aren't rusty, I would bolt the tow bar to the bumper. Also, make sure once it's hooked up that the tow bar is level. Of course use safety chains and hook up tow lights. Another thing to look into is your state's laws on towing. Most have a max speed limit of 55 and some require that you have a fire extinguisher and road flares. Before you go, make sure you check over both vehicles (tire pressure, brakes, etc.)and don't be scared, just take it easy and you'll be fine.
Artiemac is offline
post #15 of 16 Old 06-12-2013, 07:33 PM
james04si
james04si's Avatar
1977 CJ5
I basically had Eddie do the same to my bumper. He welded on attachment points for a tow bar I already had. Just put in 2 pins and its attached. I've towed mine a few hundred miles plus it comes in handy when the jeep leaves you stranded on the side of the road.
james04si is offline
deal , harbor freight , road trip , tow bar , towing
