hanging clutch pedal assy - JeepForum.com
post #1 of 2 Old 05-22-2003, 02:54 PM Thread Starter
Brandon Miller
thinking of ditching my chain drive and going hydro - what do people use for this? It's a glass body, M38A1
Brandon Miller
President of RCRC 4wd Club, Sacramento, CA
1993 ZJ. Rusty's BB and 30's. Otherwise stock. Yota with HD HP 44/60, 5.0/435/dual tcases etc etc.
Brandon Miller is offline
post #2 of 2 Old 05-22-2003, 07:00 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I'm running a SBC so it might be a little different... basically, I used a Tilton 1" bore master cylinder and a stock 80-something CJ slave cylinder and hose. I used a Camaro clutch fork and shortened it about an inch to get the right ratio for full release. I also replaced the stock slave cylinder's pushrod with one that I made out of 3/8" stock so that I could make it long enough to take up almost all the slack in the system when the clutch fork spring retracts the slave cylinder all the way in. Tilton makes several different bore sizes in their master cylinders so you should be able to find one that will work. Might even be able to run the stock 80-something master cylinder (I think it's got a 7/8" bore). My clutch is a little stiff but it's bearable. Oh another thing, I'm running an 11" disk so if you run a 10.5" disk, your pressure plate finger ratio will be better and you shouldn't need as much travel to disengage. Strive for disengagement with the smallest possible master cylinder bore for a nice easy pedal "feel"... HTH
BESRK is offline
Clutch-brake pedal assy golferwt Jeep CJ Forum 17 07-21-2016 11:30 AM
Clutch pedal Nicholson32 Jeep CJ Forum 5 08-14-2007 01:31 AM
Clutch works but I hear a whirring when I press the clutch pedal to the floor? part.changer Jeep CJ Forum 12 04-10-2007 02:31 PM
Clutch pedal Pick01 Jeep CJ Forum 2 04-03-2007 06:41 AM
HELP Clutch arm hanging up on header flange junglejeep Jeep CJ Forum 4 03-09-2004 03:52 PM
