Half Doors w/ Hard Uppers - JeepForum.com
post #1 of 6 Old 02-06-2006, 09:02 PM Thread Starter
dreski1
I have an 86 CJ that I purchased as a POS. I rebuilt from the ground up to a really nice rig (A bit of a driveway queen). I also bought some lower half doors and a hard top. The part I was missing was the upper doors, until recently. The fiberglass upper doors seem to fit, but I have no way of attaching them to the lower doors.
The uppers came with long bolts, but they simply enter a "blind" hole in the lower doors. There are no threads in the lowers.
Has anybody had this delema? Is there a solution? I am assuming I will have to weld in some nuts. Any other ideas?
Thanks,
Dave
____________________________________________
86 CJ w/ 91 YJ tub, V8 304, , HEI, T150, ACM20 w/ 33's. Chili Pepper Red.
dreski1 is offline
post #2 of 6 Old 02-07-2006, 12:00 AM
only in a jeep cj
Are the half doors (lower) metal factory doors from a Wrangler?
Next, do they have the 3 plastic hole guides for the uppers? Most of the time these are missing or break.
Do the upper sections have the squared upper corners or the rounded corners to match the hardtop?
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is online now
post #3 of 6 Old 02-07-2006, 08:27 PM Thread Starter
dreski1
The lower doors are metal and I am assuming they are from a Wrangler. On that point I cannot be certain.
They do have the 3 plastic inserts per door. None seem to be broken. Will these doors only work with "Soft Uppers"?
The "Hard Uppers" have round corners to mate up to the hard top. Physically everthing goes together, but I can't securly fasten the uppers to the lower doors.
Thank for any help!
Dave
dreski1 is offline
post #4 of 6 Old 02-07-2006, 10:14 PM
jeepskate
Having never messed with the hard uppers, my guess would be that perhaps you need to remove the interior trim panel from the YJ half doors so that you can access the insides of the doors and put some nuts on the studs.
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
jeepskate is offline
post #5 of 6 Old 02-08-2006, 07:03 AM Thread Starter
dreski1
Yeah, that is what I suspected. I have the interior trip panels removed already and trying to decide my next move.
Is this not a common configuration? Do most Jeepers have not have a Hard Top and Hard Uppers? Just curious.
Later,
Dave
dreski1 is offline
post #6 of 6 Old 02-08-2006, 10:16 AM
jeepskate
Not real common. You had a 9 year run on the YJ, hard uppers are aftermarket and were available for maybe 3-4 years of that production time (obviously they're still made now, but by a lot fewer vendors) and typically cost as much as if not more than a decent set of used full doors.
Warrior half DP hard doors texasimport Jeep CJ Forum 0 10-20-2009 09:33 AM
Soft Half Door Bottoms and uppers Q 1979CJ7 Jeep CJ Forum 6 06-25-2008 08:58 PM
CJ7 Hard top, Half Doors and Uppers dreski1 Jeep CJ Forum 1 12-07-2005 11:17 PM
half hard doors Why J? Jeep CJ Forum 0 11-09-2004 07:50 PM
Need To Buy Cj7 Half Hard Doors, Anybody Have Any For Sale, Or Know Where To Buy? Boulder4x4 Jeep CJ Forum 1 02-27-2004 06:45 AM
