half doors - JeepForum.com
post #1 of 6 Old 07-11-2013, 02:12 PM Thread Starter
jacques25150
1982 CJ7
half doors
I have found YJ doors in good condition; I will use them and transform my CJ doors to half doors;
who can give to my the dimensions of half doors to cut the CJ doors and made half doors compatible with the bestop soft top doors
thank you very much
jacques25150 is offline
post #2 of 6 Old 07-11-2013, 04:26 PM
Spieg8
1984 CJ8
I'm confused by your question... What are you trying to do?
Spieg8 is offline
post #3 of 6 Old 07-12-2013, 05:52 AM Thread Starter
jacques25150
1982 CJ7
I will cut my cj doors to made half doors for the summer;
but these doors will be compatible with bestop half doors (up part)
and it where fine to have the dimensions to made the just cuting
thank You
post #4 of 6 Old 07-12-2013, 10:00 AM
Spieg8
1984 CJ8
Don't think that's possible. Due to the latch location on the full doors, you can't cut them low enough to attach soft upper door assembly (you'd be cutting off the door latches and have no way to open the door).
Notice how high the latches sit on a full door (latch is about even with the upper door hinge)
On a half door, the latches sit much lower (latch is much lower than the upper door hinge)
If you want half doors I'd recommend buying a pair of used ones.
Spieg8 is offline
post #5 of 6 Old 07-12-2013, 01:23 PM Thread Starter
jacques25150
1982 CJ7
Ok, thank You;
but half doors are rare in france
post #6 of 6 Old 07-12-2013, 02:22 PM
Jawbox
Do you already have the soft half doors? If so, maybe what you want to do is buy or fab up a door skin for them. You could easily fab up something like this using the door frame:
http://shop.poisonspyder.com/Jeep-Do.../14-27-010.htm
Jawbox is offline
