half door torx size help, - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > half door torx size help,
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineG2 Disc Brake Conversion Kit for Jeep Wrangler YJ TJ LJ Ch
Unread 06-19-2014, 10:29 PM   #1
chris989604
1980 CJ7
Hello all,
I am trying to adjust some new half doors i picked up and the door/mirror hinge has a smaller torx. 25 will not fit and a 20 is loose. it is much smaller than the standard 40 for the windshield and lower hinge.
Any idea,, is this some aftermarket metric crap??
chris989604 is offline   Reply With Quote
Unread 06-19-2014, 10:38 PM   #2
only in a jeep cj
Might be the same size as the dash torx, T27. A T25 may/will strip it out IF its a 27. Also, those are just the side mirror base torx bolts, the T40s are underneath for the hinge.
Also, apply a few seconds of heat to each torx before you loosen them. It makes all the difference.
Ed
1975 CJ-6 304 T15 Dana20 30/44 3.73
1983 CJ-8 258 T5 300 30/44 3.31 Looking for full or half hardtop buy or trade
1986 CJ-7 Laredo 4.6 stroker T5 300 30/44 3.31
1986 TJ-7 Trail Jeep project in the works
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline   Reply With Quote
Unread 06-19-2014, 11:22 PM   #3
RenoF250
I would recommend you buy these:
http://www.harborfreight.com/12-in-D...-Pc-67896.html
http://www.harborfreight.com/6-piece...set-68015.html
And drive them with an impact screwdriver. I got all my Torx out that way. 1 did require the air impact wrench but it did come out and those bits handled it well.
I would guess your dealing with a T25 with paint in it and you will have to pound it in.
RenoF250 is offline   Reply With Quote
Unread 06-20-2014, 09:56 AM   #4
chris989604
1980 CJ7
I have the impact torx and agree that is the only way to get any of them out. As long as there is not crazy chinese special torx size I will go back to the 25 and try to work it in. Must be the paint caked in there.
Unread 06-20-2014, 11:55 AM   #5
CrankyD
1983 CJ7
Pretty sure it's a T27 as stated above. Sometimes if you are careful you can get a standard hex key or a flathead to bite, but that's not the right way and I have NEVER EVER done it that way...
CrankyD is offline   Reply With Quote
Unread 06-20-2014, 07:49 PM   #6
Matt80cj
1980 CJ7
I took a pocket knife (actually a razor blade) and cleaned out the star points first. Bit fits a lot easier and deeper.
Matt80cj is online now   Reply With Quote
Unread 08-27-2014, 11:11 AM   #7
chris989604
1980 CJ7
Found my problem, The craftman torx socket would not fit. THe Kobalt torx driver i have would. Just could not get enough muscle into it.
I ended up welding a bolt to the torx bolt and taking it off that way and then threw the craftman set in the trash.
That is officially the last craftman tool i buy, they all seam to have turned to junk
