Had a live feed during alignment - JeepForum.com
post #1 of 7 Old 06-10-2013, 02:15 PM Thread Starter
twoleos617
A local shop had a LCD in the waiting room showing the work being done live from the PC. I just replaced the ball joints beforehand.
The pics are in order of the work done. Help me make sense of the printout. Do I need shims for the front axle?
I have 3" springs and 3/4" shackles, 31" tires.
Torque is the measure of force that gets the cap off your beer.
Mike D.
twoleos617 is offline
post #2 of 7 Old 06-10-2013, 02:18 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Yes, you need about 7* shims. 5-7 degrees is caster spec.
Steel is preferable over aluminum.
Matt
Matt1981CJ7 is online now
post #3 of 7 Old 06-10-2013, 02:20 PM Thread Starter
twoleos617
can anything be done about the camber?
Mike D.
post #4 of 7 Old 06-10-2013, 02:35 PM Thread Starter
twoleos617
I'll need 4* shims right? ...to get back to 6*?
Just got a MSG that camber is corrected with adjustable ball joints.
Mike D.
post #5 of 7 Old 06-10-2013, 02:38 PM
Matt1981CJ7
1981 CJ7
Matt
Edit: (I repeat)
post #6 of 7 Old 06-10-2013, 03:37 PM
OleBlue73
1973 CJ5
I believe why the OP is asking again is because his caster is already about 2 deg per the printout. If he used 7 degree shims with 2 degree existing caster, where would that put him in the end? I don't know myself 100%, and that's why I'm reiterating his question again. Do you add in the 7 degree shims you recommend, I.e, 9 degrees? Or subtract it, I.e, 5 degrees?
1973 CJ5, 304, T15, D20
2009 JKU, Rubicon
2005 TJ, X, 4.0, 6 speed
OleBlue73 is offline
post #7 of 7 Old 06-10-2013, 03:49 PM
dnjeep
1976 CJ5
Yes, you need to get 4-5* shims and have those installed. With your existing 2* caster, that should yeild the desired 5-7* caster range.
dnjeep is offline
