H0 302 Project 84 cj7 - JeepForum.com
post #1 of 67 Old 03-24-2013, 12:51 PM Thread Starter
wonfastws6
Just started my new project installing 302h0 in my cj7. The Reason why i went with the 302 is because the previous owner installed a carburetor 302 already so I had most of the Fitment issues solved. I'm going with a painless wiring harness, External high-pressure fuel pump, advanced adapter mounts. The PO did a Terrible job with the motor mounts before. It already has a Ford T 18 behind it And a dana 300 t-case.
Sadly this is how the previous owner mounted the engine to the frame
image-3714062303.jpg   image-2876772403.jpg   image-2082453466.jpg   image-2521789407.jpg
wonfastws6 is offline
post #2 of 67 Old 03-24-2013, 03:52 PM
kappa505
1980 CJ5
Nice. Hopefully you document like crazy. What is your opinion on the position of the motor in the jeep as it sits now. It looks way lower than I have mine mocked up. How are your angles for everything? Did the po put new front and rear drive shafts.
"Nothing in the world can take the place of Persistence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education will not; the world is full of educated derelicts. Persistence and determination alone are omnipotent. The slogan 'Press On' has solved and always will solve the problems of the human race." Supposedly President Coolidge
kappa505 is offline
post #3 of 67 Old 03-24-2013, 04:18 PM Thread Starter
wonfastws6
The engine looks so much lower because it has a body lift..... I've never checked angles, but I have rode around on this set up for two years now trying to decide what i wanted to do with the motor and I haven't had any Issues.
post #4 of 67 Old 03-24-2013, 04:36 PM
Stormpaw
1983 CJ7
Yeah, that is an interesting engine mount. Mine is just about as bad. At least you can get it done right now.
I am looking forward to watching your install.
Stormpaw is offline
post #5 of 67 Old 03-24-2013, 04:38 PM Thread Starter
wonfastws6
As far as the shafts go I have no clue the PO did the work. I'm just going back through and fine tuning his set up. The trans mount looks to be in its stock location even with the ford t18 behind it Which surprised me. Ill be taking lots of piks next weekend and make sure to take some of the trans location and drive shafts and stuff like that.
post #6 of 67 Old 03-24-2013, 06:20 PM
S76
I'm in the thought process of putting a 5.0 in a 7 and think these M.O.R.E. mounts look like they are the best out there.
http://www.mountainoffroad.com/_e/Je...h_Ford_V_8.htm
I'll be following to learn. thanks.
If you always do what you've always done. You will always get what you've always got.
S76 is offline
post #7 of 67 Old 03-24-2013, 06:33 PM
mvbrady
Always good to see a FI Ford under the hood.
mvbrady is offline
post #8 of 67 Old 03-24-2013, 06:53 PM Thread Starter
wonfastws6
These are the mounts I'm using and am going to beef them up myself. A lot of guys are making there own from what I've read.
post #9 of 67 Old 03-24-2013, 10:03 PM
RDH
Just curious but why don't you go with a 351W? I'm digging the swap. You may want to look into a cam swap though.
1978 CJ7: 304, 3Spd, AMC 20 Rear, Thrush Welded Mufflers W/ Turndowns, Unknown Front, Worn out Dana 20 case
RDH is offline
post #10 of 67 Old 03-24-2013, 10:19 PM Thread Starter
wonfastws6
To be honest I thought the olde 302 had plenty of power on the trail.
post #11 of 67 Old 03-25-2013, 06:40 AM
RDH
They do, and good torque can be made easily. if it were me, I'd look into getting a custom grind done for a camshaft. The cam and intake on that thing are both more for the higher end of the RPM spectrum. If the old engine impressed you before, get a good custom grind or RV style cam to throw in there and you'll be giggling like a little girl every time you go wheeling. Sorry, I was a Ford guy in a past life. lol
RDH is offline
post #12 of 67 Old 03-25-2013, 09:56 AM
Jim1611
Jim1611's Avatar
I'd beef those mounts up too, allot in fact. What year is your engine? Good choice on the T-18 too, you'll never need to worry about it from now on if it's in good shape going in. Not sure if those mounts have the offset made into them but your engine will need to sit 1" closer to the driver's side, as is the factory engine too.
I like your engine choice too by the way.
Jim1611 is offline
post #13 of 67 Old 03-25-2013, 11:10 AM Thread Starter
wonfastws6
Definitely going to be beefing those mounts up after I do a mockup run . I know in the picture that Mount Dose not show adjustability but the other mount has like three or four different holes I'm assuming that's for the Compensation of the 1 inch to the driver side. Thanks For the info. I struggled for about two years on what I wanted to do if I wanted to stay with the 302 or maybe go with a 4bt I'm a ag/diesel mechanic so I really wanted to do the 4bt but ultimately It already had a 302 and I like the power on the trail.
post #14 of 67 Old 03-25-2013, 12:35 PM
Jim1611
Jim1611's Avatar
The 4bt would be great. Mine is getting the 5.0 too http://www.jeepforum.com/forum/f8/ji...build-1093702/.
Jim1611 is offline
post #15 of 67 Old 03-25-2013, 03:42 PM
RDH
Ha, me too! I look forward to the rest of your build. If you need to pick a smallblock Ford guy's brain, just holler.
RDH is offline
