Gushing white smoke but runs fine? - Page 2 - JeepForum.com
post #16 of 33 Old 03-04-2013, 12:00 PM Thread Starter
Mlaughlin8
1980 CJ5
If it were the head gasket, wouldn't it run really hot and overheat?
Mlaughlin8 is offline
post #17 of 33 Old 03-04-2013, 12:03 PM Thread Starter
Mlaughlin8
1980 CJ5
The drip is coming from the header/head pipe coupling and it is black... Which I guess means fuel
post #18 of 33 Old 03-04-2013, 12:31 PM
Davis77Cj
1977 CJ7
if your mechanic "changed" the oil after it dumped fuel into the block it should not be a problem. if it were me i would change the oil again and check it for gas. also i recommend that you do what Matt1981CJ7 described and work from there.
Only in America do you have the God given right to be loudly opinionated about something that you are completly ignorant of.
Davis77Cj is offline
post #19 of 33 Old 03-04-2013, 02:35 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
It's quite normal for the exhaust to drip, or spray, a little liquid when warming up. That is just condensation that develops as the system cools down being forced out. Often times it will have black sooty deposits in it, if your exhaust system is old. The drip/spray should go away in just a few seconds as the pipes heat up.
As for over-heating, I think it depends on the size of the leak. Yes, a major head gasket failure will cause over-heating, a small leak may not.
Have you even pulled the plugs to see what they look like?
Matt
Matt1981CJ7 is offline
post #20 of 33 Old 03-04-2013, 03:11 PM Thread Starter
Mlaughlin8
1980 CJ5
No, I haven't pulled the plugs. I know they are new along with the wires rotor, fuel pump, water pump, the head was redone new head gasket Ect...ill have to check them when I get home from work
post #21 of 33 Old 03-04-2013, 05:00 PM
VooDoo2
1978 CJ7
My first jeep did this. Turns out the breather hose for the T400 was hooked to vacuum. Tranny fluid = white smoke
VooDoo2 is offline
post #22 of 33 Old 03-04-2013, 07:17 PM Thread Starter
Mlaughlin8
1980 CJ5
I guess there are major problems... Oil coming out from exhaust along with the smoke, and the spark plugs are black. What went wrong with my rebuild?
post #23 of 33 Old 03-04-2013, 07:37 PM
skizriz
1978 CJ7
skizriz is online now
post #24 of 33 Old 03-04-2013, 08:13 PM
stamp32
I would not touch another thing until you talk to the mechanic that did the work. The more you investigate yourself, the more you give the mechanic leverage for denial.
Chris
stamp32 is offline
post #25 of 33 Old 03-04-2013, 08:16 PM
smokeone
I'll almost garuntee it's the gasket. Like I said my brothers head gasket went south because when he bolted it down he forgot to tourqe it and it was fresh rebuild also. I would be making the rebuilder repair it and dont't take it back until it's repaird properly. If the water gets in the oil it will wash the bearings and then it will need another rebuild.
1985 cj with 1992 wrangler body.
Its's a project for now needs more parts and money.
258 in-line 64 speed 4' lift
smokeone is offline
post #26 of 33 Old 03-04-2013, 08:33 PM
jeepwhore
..... What went wrong with my rebuild?
THAT, is a question for the "mechanic" that did the work for you. As said, don't touch a thing and take it straight back to them.
'84 CJ-7: Yota axles (spartan locked front, e-locked rear) 4" BDS, 1" Daystar & 3/8" shackle lifts, 35" X-Terrains on steelies, YJ Tub & family roll bar, heater blower upgrade, 4.2L w/MC2100 & Team Rush, Warn 8274. Rebuilt 4.2/4.0 hybrid, AX15 and twin sticks/clocking ring waiting to go in.
The advertised position for a topless, dirty jeep girl has been filled......by my wife. Thanks to all that applied.
<------------and yes, that is her.
:-D
jeepwhore is online now
post #27 of 33 Old 03-04-2013, 08:40 PM
swatson454
1983 CJ7
Either wrong or completely fubared valve seals could be a pretty strong possibility.
The guys are right, though. Stop right there or he might pull some d-bag move and say "well, you tinkered with it so... blah blah blah".
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline
post #28 of 33 Old 03-04-2013, 08:54 PM
tjeep1
1978 CJ7
i agree tell the engine builder and see if he wants to tow it there, i wouldnt even drive it. dont touch a thing thats just ammo for his incompatence on the build
tjeep1 is offline
post #29 of 33 Old 03-04-2013, 08:59 PM Thread Starter
Mlaughlin8
1980 CJ5
He won't do that to me, he's a family friend and we are bartering work with each other... He's doing my motor rebuild and I'm welding up a big car port for his shop...
post #30 of 33 Old 03-04-2013, 09:02 PM
swatson454
1983 CJ7
Oh good. Let's hope it's something simple like a bad valve seal/s.
Good luck with it!
Shawn
