Guess the connector ? - JeepForum.com
post #1 of 10 Old 11-01-2012, 11:45 AM Thread Starter
Nickodemo
1978 CJ7
This is the last connector that I cant figure out. 1978 CJ7. under dash near steering column. Colors are two red solid and a white w tracer.
I also have three wires comming out of the harness together with the flat single connectors (orange,yellow black) . Any help would be great.
Nickodemo is offline
post #2 of 10 Old 11-01-2012, 01:38 PM
scooter71954
2016 JK Wrangler
It is the connector for the backup lights with automatic transmission.
This is not a restoration! My goal is stop the rust, mechanically sound and easy on the pocketbook.
scooter71954 is offline
post #3 of 10 Old 11-01-2012, 01:49 PM
Renegade82
1982 CJ7
Sounds right. It slides over 2 flat topped posts that stick out, perpendicular to them, as opposed to a spade terminal that slides together parallel.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #4 of 10 Old 11-01-2012, 03:05 PM
John Strenk
John Strenk's Avatar
1976 CJ5
Not exactly,
It plugs into the back of the PRNDL switch on the steering column. Normal spade terminals.
There is also a NSS connector (Two Blue wires) with jumper installed for manual tranny
And a Kick down switch (two Yellow Wires)
John Strenk is offline
post #5 of 10 Old 11-02-2012, 12:01 PM
Renegade82
1982 CJ7
Oh, my bust. It looked like one of those that slide over 2 contact posts. Not sure what they're called but they're like a cylindrical tee post where the top of the tee contacts the side of a spade.
post #6 of 10 Old 11-02-2012, 12:16 PM Thread Starter
Nickodemo
1978 CJ7
Thanks guys, It hit me last night as I was looking at the diagram. I have the manual trans and this plug is unused.
post #7 of 10 Old 11-03-2012, 03:44 AM
John Strenk
1976 CJ5
Your correct in that it's used on the "T" connectors in other places. One plug for multple uses.
post #8 of 10 Old 11-04-2012, 11:17 AM
scooter71954
2016 JK Wrangler
I believe those "T" connectors are commonly referred to as "nail head" connectors
post #9 of 10 Old 11-05-2012, 10:18 AM
Renegade82
1982 CJ7
Okay, now it makes sense. The 'ol multiple use option.
post #10 of 10 Old 11-16-2012, 11:27 AM Thread Starter
Nickodemo
1978 CJ7
still confused
So if I have a manual trans do I jumper the REDRED/White connector. The switch on the trans has two white wires on it. As it is now my backup lights do not come on when I shift into reverse. They do blink with the turn signal and I do not think that is correct?
